Full Version: "Kodi is starting..." message - Nothing happens
Hey everybody,
quite new to the APT2 XBMC (Kodi) community. I have the APT2 with Software 5.0.2 jailbroken and been running XBMC for the past 3-4 years. I never really had any problems until one day on startup of XBMC the message shows "XBMC is starting", but nothing would happen, it would stuck on the same screen.
So I found out that there is Kodi and figured that would be the reason. So I installed Kodi through Terminal and Nito and also uninstalled XBMC as discussed in other posts.
Now when I try to run Kodi the same message appears as "Kodi is starting...", but noting happens...
Anybody any solutions? And remember I'm new to the Terminal/Upgrade topics lol
Help is much appreciated
Thx
The fact that you are new to all the terminal stuff - i would recommend in rejailbreaking the whole thing and start from scratch.
If not - in that stage there is no kodi.log written yet - you would need to activate syslog and then provide /var/log/syslog so i could see whats going on.
Haha fair enough!
You figure rejailbraking would be easier?! Can you guide me to an easy guide on how to rejailbrake?!
Thanks a lot for your help!
forum.firecore.com for jailbreak questions - yep i think rejailbreak is easier then debugging your issue and at the end only coming to the conclusion that you need to rejailbreak Wink
Just get semi restore to rejailbreak. It's a quick process
Any chance you could guide me to a good thread for a rejailbreak?!
I'll see what I can find! Thanks
