Full Version: Series Link = Sunday?
I'm running mediaportal server on a Win7 server, accessed via two openelec boxes. (Latest version)
I've recently started to use the PVR more and more but have noticed if I set a weekly repeating recording for any day/time, for instance 1800-1900 Wed, after its set and you check it in Timers, it ALWAYS says Sunday. The date and time the recording is due to start is correct but the repeat day is shown as sunday so I imagine the first recording may work but repeats will then be on Sunday not wednesday.
Anyone else seen this behavior?
Actually, it shows correctly on within Mediaportal TV server, so its the plug in that is wrong. I'm using Confluence so unlikely skin related.
I haven't seen this one before. Will try to reproduce it here and (when needed) fix it.
Hi Margro, Its odd as its on both 14.0 and 14.1, under Confluence and other skins. You'd think if it was a skin issue Confluence would be unlikely to be affected being the default least buggy skin.
Found the problem. Will be fixed in the next version of the addon. Thanks for reporting.
Top man.
