Here is the class that creates the window containing the search results...
# -*- coding: utf-8 -*-
# Copyright (c) 2010 Correl J. Roush
import sys
import base64
import threading
import xbmc
import xbmcgui
from basictypes.bytes import Bytes
import transmissionrpc
import searchall
import common
import os
import traceback
from default import BASE_MEDIA_PATH
_ = sys.modules[ "__main__" ].__language__
__settings__ = sys.modules[ "__main__" ].__settings__
KEY_BUTTON_BACK = 275
KEY_KEYBOARD_ESC = 61467
KEY_MENU_ID = 92
EXIT_SCRIPT = ( 6, 10, 247, 275, 61467, 216, 257, 61448, )
CANCEL_DIALOG = EXIT_SCRIPT + ( 216, 257, 61448, )
UPDATE_INTERVAL = 1.0
STATUS_ICONS = {'stopped': 'pause.png',
'seeding': 'ok.png',
'downloading': 'down.png'}
class TransmissionGUI(xbmcgui.WindowXMLDialog):
def __init__(self, strXMLname, strFallbackPath, strDefaultName, bforeFallback=0):
self.list = {}
self.torrents = {}
self.timer = None
def set_settings(self, params):
__settings__.setSetting('rpc_host', params['address'])
__settings__.setSetting('rpc_port', params['port'])
__settings__.setSetting('rpc_user', params['user'])
__settings__.setSetting('rpc_password', params['password'])
def onInit(self):
p = xbmcgui.DialogProgress()
p.create(_(32000), _(32001)) # 'Transmission', 'Connecting to Transmission'
try:
self.transmission = common.get_rpc_client()
except:
p.close()
self.close()
(type, e, traceback) = sys.exc_info()
message = _(32900) # Unexpected error
if type is transmissionrpc.TransmissionError:
if e.original:
if e.original.code is 401:
message = _(32902) # Invalid auth
else:
message = _(32901) # Unable to connect
if xbmcgui.Dialog().yesno(_(32002), message, _(32003)):
__settings__.openSettings()
elif type is ValueError:
# In python 2.4, urllib2.HTTPDigestAuthHandler will barf up a lung
# if auth fails and the server wants non-digest authentication
else:
xbmcgui.Dialog().ok(_(32002), message)
return False
self.updateTorrents()
p.close()
self.timer = threading.Timer(UPDATE_INTERVAL, self.updateTorrents)
self.timer.start()
def updateTorrents(self):
list = self.getControl(120)
self.torrents = self.transmission.info()
for i, torrent in self.torrents.iteritems():
statusline = "[%(status)s] %(down)s down (%(pct).2f%%), %(up)s up (Ratio: %(ratio).2f)" % \
{'down': Bytes.format(torrent.downloadedEver), 'pct': torrent.progress, \
'up': Bytes.format(torrent.uploadedEver), 'ratio': torrent.ratio, \
'status': torrent.status}
if i not in self.list:
# Create a new list item
l = xbmcgui.ListItem(label=torrent.name, label2=statusline)
list.addItem(l)
self.list[i] = l
else:
# Update existing list item
l = self.list[i]
l.setLabel(torrent.name)
l.setLabel2(statusline)
l.setProperty('TorrentStatusIcon', STATUS_ICONS.get(torrent.status, 'pending.png'))
l.setProperty('TorrentID', str(i))
l.setProperty('TorrentProgress', "%3d%%" % torrent.progress)
removed = [id for id in self.list.keys() if id not in self.torrents.keys()]
if len(removed) > 0:
# Clear torrents from the list that have been removed
for id in removed:
del self.list[id]
list.reset()
for id, item in self.list.iteritems():
list.addItem(item)
list.setEnabled(bool(self.torrents))
# Update again, after an interval, but only if the timer has not been cancelled
if self.timer:
self.timer.start()
def onClick(self, controlID):
if (controlID == 111):
kb = xbmc.Keyboard('', 'Search')
kb.doModal()
if not kb.isConfirmed():
return
terms = kb.getText()
p.create(_(32000), _(32290))
try:
engines = searchall.SearchAllMt(1, terms)
engines.search()
results = engines.torrents
except Exception as e:
traceback.print_exc()
# xbmcgui.Dialog().ok("tracking error", str(traceback.format_exc()))
p.close()
xbmcgui.Dialog().ok(_(32000), _(32292))
return
p.close()
if not results:
xbmcgui.Dialog().notification(_(32000), 'No Torrents Found', xbmcgui.NOTIFICATION_INFO)
return
srw = SearchResults("script-Transmission-searchresults.xml", __settings__.getAddonInfo('path'), "Default")
srw.transmission = self.transmission
srw.results = results
srw.doModal()
del srw
return
if (controlID == 112):
# Remove selected torrent
item = list.getSelectedItem()
selected_rm = xbmcgui.Dialog().select(_(32000),['Torrent and Data','Torrent','Cancel'])
if selected_rm == 0 and item:
self.transmission.remove(int(item.getProperty('TorrentID')), True)
elif selected_rm == 1 and item:
self.transmission.remove(int(item.getProperty('TorrentID')), False)
if (controlID == 113):
# Stop selected torrent
if item:
self.transmission.stop(int(item.getProperty('TorrentID')))
if (controlID == 114):
# Start selected torrent
if item:
self.transmission.start(int(item.getProperty('TorrentID')))
if (controlID == 115):
# Stop all torrents
self.transmission.stop(self.torrents.keys())
if (controlID == 116):
# Start all torrents
self.transmission.start(self.torrents.keys())
if (controlID == 117):
# Exit button
self.close()
if (controlID == 118):
# Settings button
prev_settings = common.get_settings()
try:
p.close()
except:
p.close()
xbmcgui.Dialog().ok(_(32002), _(32901))
# restore settings
self.set_settings(prev_settings)
try:
except err:
self.close()
if (controlID == 120):
# A torrent was chosen, show details
w = TorrentInfoGUI("script-Transmission-details.xml", __settings__.getAddonInfo('path') ,"Default")
w.setTorrent(self.transmission, int(item.getProperty('TorrentID')))
w.doModal()
del w
def onFocus(self, controlID):
pass
def onAction( self, action ):
if ( action.getButtonCode() in CANCEL_DIALOG ) or (action.getId() == KEY_MENU_ID):
self.close()
def close(self):
if self.timer:
self.timer.cancel()
self.timer.join()
super(TransmissionGUI, self).close()
class SearchResults(xbmcgui.WindowXMLDialog):
def __init__(self, strXMLname, strFallbackPath, strDefaultName):
self.results = []
self.transmission = None
def onInit(self):
bkgrd_img_path = os.path.join(BASE_MEDIA_PATH, 'transmission-dialog.png')
self.bkgrd_image = xbmcgui.ControlImage(0, 0, 850, 540, bkgrd_img_path)
self.addControl(self.bkgrd_image)
self.close_button = xbmcgui.ControlButton(740, 0, 64, 32, '',
'DialogCloseButton-focus.png', 'DialogCloseButton.png')
self.addControl(self.close_button)
self.rlist = xbmcgui.ControlList(32, 32, 790, 520,
buttonFocusTexture='list-bg-selected-nofocus.png',
_itemTextXOffset=5, _itemTextYOffset=-1, _imageWidth=16,
_imageHeight=16)
self.addControl(self.rlist)
for result in self.results:
label = '%s' % result['name']
label2 = '%s (%d)' % (result['size'], result['seeds'])
litem = xbmcgui.ListItem(label=label, label2=label2, iconImage=result['icon'])
self.rlist.addItem(litem)
self.setFocus(self.rlist)
self.close()
def onClick(self, control):
sel_pos = self.rlist.getSelectedPosition()
if control == self.close_button.getId():
self.close()
elif control == self.rlist.getId():
try:
self.transmission.add_torrent(self.results[sel_pos]['url'])
self.rlist.removeItem(sel_pos)
self.results.pop(sel_pos)
if sel_pos == self.rlist.size():
self.rlist.selectItem(sel_pos-1)
else:
self.rlist.selectItem(sel_pos)
except:
xbmcgui.Dialog().notification(_(32000), _(32293), xbmcgui.NOTIFICATION_ERROR)
class TorrentInfoGUI(xbmcgui.WindowXMLDialog):
self.torrent_id = None
self.list = {}
self.timer = None
def setTorrent(self, transmission, t_id):
self.transmission = transmission
self.torrent_id = t_id
self.timer = threading.Timer(UPDATE_INTERVAL, self.updateTorrent)
self.timer.start()
def updateTorrent(self):
pbar = self.getControl(219)
list = self.getControl(220)
labelName = self.getControl(1)
labelStatus = self.getControl(2)
labelProgress = self.getControl(11)
torrent = self.transmission.info()[self.torrent_id]
files = self.transmission.get_files(self.torrent_id)[self.torrent_id]
statusline = "[%(status)s] %(down)s down, %(up)s up (Ratio: %(ratio).2f)" % \
if torrent.status is 'downloading':
statusline += " ETA: %(eta)s" % \
{'eta': torrent.eta}
labelName.setLabel(torrent.name)
labelStatus.setLabel(statusline)
labelProgress.setLabel('%3d%%' % (torrent.progress))
pbar.setPercent(torrent.progress)
for i, file in files.iteritems():
l = xbmcgui.ListItem(label=file['name'])
list.addItem(l)
self.list[i] = l
else:
l = self.list[i]
l.setProperty('Progress', '[%3d%%]' % (file['completed'] * 100 / file['size']))
self.timer.start()
def onInit(self):
self.updateTorrent()
def close(self):
if self.timer:
self.timer.cancel()
self.timer.join()
super(TorrentInfoGUI, self).close()
def onAction(self, action):
if (action.getButtonCode() in CANCEL_DIALOG) or (action.getId() == KEY_MENU_ID):
self.close()
pass
if controlID == 111:
self.close()
pass
if __name__ == '__main__':
print 'test'
