hi. i am new to kodi, tvheadend and raspberry. could make it to compile tvheadend as server.
now i am missing pvr add ons in my kodi. not in enabled. disabled not even shows up.
can i compile those for raspian?
@wrxtasy:
The addon is a client addon. I think scuba303 is looking for tvheadend using as backend/server at the same board. I'm looking for this option too. The client addon works fine. The one you linked to and the one what is implemented in the actual 5.0.4 version. So, does anybody know, if it is possible to install TVH as backend at the same machine openelec/kodi is running?
Yes. Very possible. The TV Headend server (i.e. the backend) has moved to the Unofficial OpenElec repo, and is in "Services" I think. I've given some tips in a thread here :
http://forum.kodi.tv/showthread.php?tid=217708 These are possibly a bit UK DVB-T specific, but may be useful to others.
I run TV Headend with both DVB-T/T2 and DVB-S/S2 USB tuners on Pis (and now Pi 2s)
OK. I found the addon and installed it. It works! The main "problem" was to understand the new TVH GUI and to start the services scan. But that is not a KODI related subject. Thanks for your help!
