Full Version: Any skinner willing to mod?
Any skinner willing to do a mod of Experience 1080?
Not many changes but some.
I tried editing it myself but howly not that easy..
Changes i would like:
- Add 2 more views
- Possibility to use media case.
- Possibility to use musicvideo playlist in widget music
- Bring back musicvideos part.
- Bring back games tab.
Why not use the MB3 mod seems like it's what you're after
MM i would but it doenst add the things i want no?
I want movie wall view like in aeon mq5 + right list view, those arent in that mod
not sure if the musicvideos part , and things for playlist are in it. and about the games tab
gonna try and see though
(2015-02-24, 18:21)Skank Wrote: [ -> ]MM i would but it doenst add the things i want no?
Is this what you mean?
EDIT: I think this is what you where after but its close enough
The one beneath is indeed what i mean
+ you can see the use of case types too there
I'm sure if you asked im85288 he might consider adding something similar
i will
Just tested the skin, it indeed is a bit better however..
Some things not sure if its possible with existing mod, or if it needs to be added/changed
(2015-02-24, 11:27)Skank Wrote: [ -> ]Changes i would like:
- Add 2 more views
Games Work, I press games under apps and it fires up advanced launcher. Never used music videos
I meant categories
