2015-02-26, 12:47
2015-02-26, 12:49
Ensure that the display driver is uptodate.
2015-02-26, 13:03
yes my display driver is up to date to the latest update
2015-02-26, 20:28
I uninstalled kodi and clean registry and reinstall it but still getting an error
2015-02-27, 00:56
Update display drivers with latest website drivers (not from windows update).
2015-02-27, 03:55
It is possible that your gfx card just doesn't cut it. http://kodi.wiki/view/Supported_hardware
2015-02-27, 06:09
I have the G force gtx460 with its latest driver from Nvidia website
2015-02-27, 18:44
You need some log to see what is happening and why it's tripping up. Make sure you are installing with administrator with privileges, and you have direct x9 available. According to the wiki table Nvida needs to be series 6 or better (not sure what series your card is) but from the forum it looks like other users have run versions of XBMC with that card.
delete C:\Users\Your_User_Name\AppData\Roaming\Kodi and re-install
Use an advancedsettings.xml file with debug enabled in that file http://kodi.wiki/view/Log_file/Advanced
2015-02-27, 20:30
I delete the folder from AppData\Roaming and reinstalled program all from scratch and still getting the same error message. It won't open for me to get no where use advanced setting
2015-02-27, 20:38
Try this go to regedit.exe > hkey current user > software > kodi then right click the folder and delete it. Restart your computer. Go to control panel and make sure kodi is not there, if is still there uninstalled from there as well. Restart again. Install a fresh copy of kodi or xbmc i suggest installing xbmc because it's been around longer xbmc 13.2
Let me know how everything goes.
before you do this i have one question are you starting kodi from a desktop shortcut?
2015-02-27, 20:48
You have to manually make the advancedsettings.xml file with a text editor see link above.
copy and paste this into it
<advancedsettings>
<loglevel>2</loglevel> <!-- Change this to "1" to hide the on-screen debug log text -->
</advancedsettings>
save off as advancedsettings.xml an place in the C:\Users\YOUR_NAME\AppData\Roaming\Kodi\userdata
<advancedsettings>
</advancedsettings>
2015-03-03, 22:20
Well I guess kodi won't work on my machine . I tried everything and it won't as much as open. I installed it on my Samsung galaxy 4 and it open but will not open on my pc
2015-03-04, 02:14
Silly question, but does the computer have audio devices attached/installed?
Try this branch build: http://mirrors.xbmc.org/test-builds/win3...crease.exe
