2015-02-26, 19:39
I've been using Kodi and pvr.wmc for a few weeks now and am loving it. I use Roomie Remote on an ipad for control and they recently integrated their TV Guide app with Kodi.Works great except inconsistencies in channel numbers.
For example, on Roomie when I select channel 125 (History Channel) it sends a ".channel set 125" command. That should work as 125 is History Channel on my provider, in the Kodi EPG, and on Roomie's guide. However, it actually tunes to Bravo (channel 184 on my provider and in the EPG).. Punching in 125 on my keyboard works as expected. After a bit of investigating, it appears as though Kodi assigns channel 125 to Bravo (channel 184 on my provider). I confirmed this by disabling "always use the channel order from the backend" and "use backend channel numbers"
I have tried every combination of those 2 settings, restarting Kodi between each change, but I cant get it to work properly. It is my understanding that "use backend channel numbers" should be the setting to use to fix this problem but it does not.
Any suggestions? Reassigning numbers in the EPG doesn't seem to affect the numbers that Kodi uses behind the scenes.
thanks
rob
thanks
rob
