I have tried the route at the end, but when I get to Get add-ons, I cannot find XBMC.org Add-ons
Is there anything else I need to do to allow me to find it please
I am using the latest KODI 14.2 Beta 1
Navigate to Settings
Add-ons
Get add-ons
XBMC.org Add-ons
Skins
Rapier
Install
Hi JohnWB.
In Kodi 14.x the repo is Kodi Add-on repository. I have updated the official thread and the wiki (sorry about the confusion).
If that doesn't work, you can download and install Rapier manually from zip using this link:
http://mirrors.xbmc.org/addons/helix/ski...-7.2.0.zip
Hello,
I've the same problem : Rapier is not listed on the Kodi repo.
I don't understand why, and when i try to install manually, Openelec says that all dependancies are not satisfied.
Hi jrozelle and welcome to the forums
Do a force refresh of the add-on repository (from the context menu) and everything should be fine after the updates are finished.
Did this help?
that's what I do before asking my question
Still no Rapier in sight.
Which version of Kodi do you use?
I'm french, and my Openelec/Kodi is in french => it can be a problem ?
No, that should not at all be the problem.
Whicj version of Kodi do you use?
If you get a "dependencies not met" error, it means that something is not updated.
Openelec 5.0.5 / Kodi 14.2
I think I've a "dependencies not met" (I've the message in french, It seem to be se same).
I force update, but nothing more.
In skins list ("theme" in french, I don't have Aeon MQ neither)...
Okay, find out.
But Kodi indicate that the skin is not compatible.
That's weird.
I don't use Openelec, but I'm sure it's not skin related.
Could you ask in the help and support forums?
I'm very interested to hear about this issue
Okay ;-)
I'll do that !
Thank you !
Allready done...
I think I found :
17:11:57 T:1968706080 DEBUG: Addon skin.rapier requires script.randomandlastitems version 2.2.1 which is not available
But do you see the skin in the Kodi repo from within Kodi?
- Navigate to Settings
- Add-ons
- Get add-ons
- Kodi Add-on repository
- Skins
- Rapier
- Install
