2015-02-28, 11:35
Hi there,
Love this Skin and am a long time user.
I am currently setting up a new Raspberry pi for my guest room and I usually Add some music playlists to the Home screen.
Usually when I add a playlists that is in my favourites it will ask me "Do you want to play the Playlists instead of entering"
This is a great function cause I do not want it to enter the playlist.
Strangely on the Pi I am setting up it does not give me that option. It goes straight to the enter Title screen.
I am using Raspberry Pi b+ on the latest Openelec with Amber 2.0.12
On my other pi and on my computer I do not get this issue.
I have been trying to solve this issue but do not find the cause of this.
Can somebody help me please?
Thanks in advance
Edit 02.03.15:
I found a solution to the problem.
It was because I had the songs stored on the sd card of the pi inside the music folder.
As soon as I use a usb drive then it works and the skins sees the favourite as playlist and will give me the option to directly play the file.
I do not know if this is an issue with Amber or Kodi
Thanks in advance
Edit 02.03.15:
