Full Version: all client pvrs broke after upgrade to v14
live tv and npvr were working until upgrade to v14
first run says no pvr addons found, and disabled live tv
navigated to pvr clients
none of them will install
all say missing dependency
reboot, try again to install next pvr
see this in log
pvr.nextpvr requires xbmc.pvr version 1.9.0 which is not available
not smart enough to fix
I had a similar problem. Had to delete Kodi and re-install. I also deleted previous installs of XBMC and all is well. Had to navigate to userdata to find add-on folder and delete that as well.
also, 14.1 addresses some issues with PVR functionality as well.
Make sure you start out using confluence and get your PVR working before adding skins. I had an issue with a skin script that needed to be removed before everything worked..
Good luck!
