As the title says. Valid comskip txt and/or EDL files don't work with my recordings on OpenELEC 5.0.5 on Pi 2. Tried both omxplayer and dvdplayer, neither work. Worked fine on my old Windows PC running Kodi 14.1
Upon further testing, the txt/EDL files do not work only when played from the PVR recordings screen. When the same files are played manually through the file manager, it works perfectly. Using VNSI/VDR if that matters, is it related to the addon at all? Should I post this over in the subforum?
