2015-03-04, 06:51
2015-03-04, 20:08
push
2015-03-05, 08:38
not sure if I get your question. make zip creates a zip file which you can install from kodi.
2015-03-05, 13:00
you got it - i didn't know about make zip... thanks
may i ask another question - not related to vnsi/vdr but to script-addons in general - if there is a resources/language/Englisch directory with a single strings.xml and i copy the directory English to "German" and translate the strings.xml - what else is needed to see the translation/tramslated texts?
2015-03-05, 13:13
where do you see a string.xml? we use string.po, which is the files we look for the translated strings
2015-03-05, 14:57
i am fiddling around with an outdated asterisk addon - and there is a strings.xml inside resources/language/Englisch ......
iforget about it - thanks for your help with make zip - that worked fine for me
