2015-10-08, 10:49
Hello, I have a lenovo ovu710018 reciever that is recognized as a "mce usb ir - spinel plus" in windows 7. Is there anything I can do to get it recognized as an ehome receiver or am I screwed?
(2015-10-08, 10:49)baroonin Wrote: [ -> ]Hello, I have a lenovo ovu710018 reciever that is recognized as a "mce usb ir - spinel plus" in windows 7. Is there anything I can do to get it recognized as an ehome receiver or am I screwed?
(2015-03-08, 07:25)Warner306 Wrote: [ -> ]4. CREATING A KODI ACTIVITY – MICROSOFT eHOME DEVICES
By this point, two devices should be added to your Harmony profile:Adding an Activity
- MCE Keyboard
- Windows Media Center SE
MyHarmony:Legacy Software:
- Choose Custom activity and follow the on-screen instructions.
From the Activities tab:
Power On and Off – Only one device should be used to power the system on and off. I recommend Windows Media Center SE for this purpose. Leaving the computer off when not in use is the recommended setting. The Off state may be wake from sleep/hibernate, or wake from a power off state if your motherboard supports this.
- Select Manual Activity;
- Choose Utility;
- Generic Activity;
- Add Required Devices;
- Complete Set-up.
Customizing Buttons – Harmony Keymap
To customize the remote, commands from the Kodi keymap must be matched to commands for a device in the Harmony database. Most key commands (e.g. "I") can be matched directly to the MCE Keyboard, so this process can usually be planned without looking up anything in the Harmony software. The idea is to match commands in the Kodi keymap with a corresponding button on the remote.
Below is an example starter keymap for a Harmony 650. This keymap covers most of the essential commands for navigation and playback and is a good launching point for a more elaborate key design.
Click here for a complete list of Kodi keyboard commands.
eHome: Basic Keymap – Harmony 650:
Basic Keymap Command List:
Harmony --> Kodi Command --> Device
*Cust (Start) --> Start Kodi --> Win + # (SE)
Cust (Quit) --> Quit Kodi --> Alt + F4 (MCE)
Cust (Full) --> Fullscreen --> Tab (MCE)
Cust (Codec) --> Codec Info --> O (MCE)
Menu > Shutdown Menu > S (MCE)
Exit --> Back --> Backspace (MCE)
Info --> Info --> I (MCE)
Guide --> Contextual Menu --> C (MCE)
Up Arrow --> Jump to Top --> Home (MCE)
Down Arrow --> Previous or Home --> Esc (MCE)
Cust (Watched) --> Watched Status --> W (MCE)
Cust (Item Up) --> Move Item Up --> U (MCE)
Up --> Up --> DirectionUp (SE)
Down --> Down --> DirectionDown (SE)
Left --> Left --> DirectionLeft (SE)
Right --> Right --> DirectionRight (SE)
Channel Up --> Page Up --> ChannelUp (SE)
Channel Down --> Page Down --> ChannelDown (SE)
OK --> OK --> Enter (SE)
Prev --> Player Controls --> M (MCE)
Play --> Play --> Play (SE)
Stop --> Stop --> Stop (SE)
Rewind --> Rewind --> Rewind (SE)
Fast Forward --> Fast Forward --> FastForward (SE)
Skip Back --> Skip Backward --> , (MCE)
Skip Forward --> Skip Forward --> . (MCE)
Pause --> Pause --> Pause (SE)
0 to 9 --> Number Keys --> 0 to 9 (MCE)
*Start Kodi – The command Win + # is a means of opening a program in Windows. The # refers to the program's position on the Taskbar. Pressing Win + 3, for example, would open the third item on the Windows Taskbar.
Advanced Configuration – keyboard.xml
It is possible to add commands not included in the list of Kodi keyboard controls by creating a file called a keyboard.xml. For example, if I wanted a command to return to the home screen, I would add the following to my keyboard.xml:
keyboard.xml:
<keymap>
<global>
<keyboard>
<esc mod="ctrl">ActivateWindow(home)</esc>
</keyboard>
</global>
</keymap>
The entry in the Harmony software would look like this:
Down Arrow (Harmony) --> Home --> Cntrl+Esc (SE)
If I wanted to map commands already assigned to other keys for specific circumstances, such as fullscreen playback, subsections could be added:
<keymap>
<FullScreenVideo>
<keyboard>
<home>subtitledelay</home>
<esc>AudioNextLanguage</esc>
</keyboard>
</FullScreenVideo>
</keymap>
The above file should be created in a text editor such as Notepad or Notepad++ and saved as keyboard.xml. The .xml must be stored at the following location:
C:\Users\USERNAME\AppData\Roaming\Kodi\userdata\keymaps
Click here for a complete list of Kodi Action IDs.
Click here for a complete list of Kodi built-in functions.
More information on the formatting and contents of a keyboard.xml can be found here.
Link: Another take on how to bind a key to a custom command.
(2015-10-13, 16:45)HTFanatic Wrote: [ -> ](2015-03-08, 07:25)Warner306 Wrote: [ -> ]4. CREATING A KODI ACTIVITY – MICROSOFT eHOME DEVICES
- MCE Keyboard
- Choose Utility;
- Generic Activity;
- Complete Set-up.
keyboard.xml:
<keymap>
<global>
<keyboard>
</keyboard>
</global>
</keymap>
<keymap>
<FullScreenVideo>
<keyboard>
</keyboard>
</FullScreenVideo>
</keymap>
Although I have the Harmony "Ultimate" (with the Hub that comes with it), just to get an idea of how this whole thing works as described in this post above, If I correctly follow the directions here with regards to the "Custom Activities" setup directions and then "Required Devices", say for example if I had the "Harmony 650" model remote, would I then be able to use my "Harmony 650" to control Kodi and all of the buttons labeled in the image would work as is (ie based on the button mapping in the image, everything would work including each button without having to perform any other setup steps or programming the remote). Since I have the Harmony "Ultimate" version instead of the Harmony 650, should I just trust the process of these steps and then "test" out my Harmony "Ultimate" by pressing some of the buttons on the remote (after following the directions in this post of course) and seeing what it does within Kodi to see if my Harmony Ultimate maps out all of the functions described in the Harmony 650 image in the above post (and also to see and discover which buttons/functions my Harmony Ultimate is not able to map)
In other words, when you say "here is a Starter Keymap" when you posted the image with what each button on the Harmony 650 will be able to do with Kodi, does that mean that by going into "Customer Activities" then "Required Devices" and follow the directions in your post above, then the "Starter Keymap" you describe will automatically enable the Harmony remote to start controlling Kodi without having to do anymore setup steps?
(2015-10-31, 00:30)Tinggi Wrote: [ -> ]Your guide outlines what I am looking to do but with a home theatre setup located in the other room. I have MINIX-8H, Apple Tv and TV Box that I access through a ELAN HC4 controller. Presently As I use 'g-Mobile 7' app on android/apple pad to turn run the MINIX, Apple and TV Box. KORE works well once into KODI.
The remote connects via WiFi to the Controller so the Harmony One is not applicable (IR).
Is there a IR to WIFI peripheral that you know of?
Presently not real streamlined so the ability to use the Harmony One would be excellent BUT I think it is not practical from what I can tell.
If you had any comments I would really appreciate it.
Regards,
David
(2015-11-01, 20:57)Tinggi Wrote: [ -> ]Kind of the direction I was thinking I need to go! So if upgrading to RF Logitech remote is required for RF capability now I ask myself if it may be better to just put the money in to the new NEEO remote. From what I read it would be a pretty simple to set up and may even be a better choice.(not taking anything away from Harmony One as they are very simple to run).
Thanks for the thoughts.
David
(2015-11-02, 02:09)Tinggi Wrote: [ -> ]It is very new. From what I read it is purported to be the most advanced Universal Remote available. Now to confirm if it will control KODI or HTPC is the next question.
As I am pretty green at this I will need to dig further. It may be that the Logitech equipment may be the best choice.
Again, thanks for the support. What part of Canada?
David
(2015-11-23, 04:23)SeattleMaverick Wrote: [ -> ]Hi Warner306,
This is by far the best guide i have found online to setup the harmony remote with XBMC. Thank you for taking time and effort for doing this.
I am also trying to set up my Harmony Ultimate with Kodi 15.2 Isengard which i upgraded last night. But I can't get Harmony to work with this IR receiver with Microsoft Windows Media Center CE in MyHarmony Software.
Below is my set-up:
HTPC: Windows 7 Ultimate 64bit
Kodi: 15.2 Isengard
Remote: Harmony Ultimate
Pic#1
IR Receiver: came with Hauppauge WinTV HVR 1265 TV tuner card which is installed in PCI Express slot of same HTPC.
Pic#2
I can this IR receiver as a Microsoft eHome Infrared Transceiver in device manager.
Pic#3
I then added both the devices, Microsoft MCE Keyboard and Microsoft Windows Media Center CE in MyHarmony Software.
Pic#4
created a Activity in MyHarmony software called "Kodi"
Pic#5
Pic#6
Then I customized the activity to launch the "Kodi" which i pinned to taskbar at # 1 position.
Pic#7
Pic#8
I also tried to set up the buttons to work as win+1, Alt+F4 and also direction keys with arrow keys but Logitech remote is not able to send any signals to this IR receivers. All these commands like win+1, Alt+F4 are working with the wireless keyboard i have.
Pic#9
Pic#10
Pic#11
The remote that came with Hauppauge WinTV HVR 1265 work perfectly well with WinTv8 application to watch the Over the Air TV on HTPC.
I am not sure if I am missing anything. How would I debug this and make it working? I don't want to use the wireless keyboard for Kodi.
Any pointers/help will be much appreciated.
Thank you in advance.
