Full Version: [Release] Duration script - Display movies runtime in hours & minutes
Pages: 1 2 3 4
Hi all,
It was annoying me to see movies durations in minutes (for exemple: 157 minutes means nothing for a human being) so I wrote a script to fix this.
I prefer durations in HH:MM or HHhMM format so that's what this script do, it converts movies duration from minutes to hours & minutes to display it on a human-readable way.
2h35 is easier to understand than 155, right ?
I released it here : https://github.com/twolaw/script.duration
(updated in december 2017 thanks to axbmcuser work, available here : https://github.com/axbmcuser/_repo/tree/..._axbmcuser )
Of course, your kodi skin has to be tweaked to trigger the script and to display the value calculated.
HOW TO TWEAK YOUR SKIN
Exemple: for the Estuary skin, these 2 xml files need to be modified as follow :
Variables.xml
Add this new variable at the end of the file (before the </include>) :
    <variable name="ItemDuration">
        <value condition="System.HasAddon(script.duration) +
                    [Window.IsVisible(Videos) | Window.IsVisible(Movieinformation)] +
                    !String.IsEmpty(Window(Home).Property(Durations.Hours)) +
                    !String.IsEqual(Window(Home).Property(Durations.Hours),0) +
                    !String.IsEmpty(Window(Home).Property(Durations.DBID)) +
                    String.IsEqual(Window(Home).Property(Durations.DBID),ListItem.DBID)">$INFO[Window(Home).Property(Durations.HoursMinutes)]</value>
        <value>$INFO[ListItem.Duration] min</value>
    </variable>
Includes.xml
Replace <label>$INFO[ListItem.Duration,, $LOCALIZE[31132]]</label> with <label>$VAR[ItemDuration]</label>
This way, your skin can still display a duration even if the script.duration is not installed.
It's my first script, so it must be far from perfection but it fully works on my HTPC. Blush
Tell me what you think of it.
It works nice,thank you .
Would it be possible to have a look at your variables.xml to see how conditions are handled ? I know i have to use $INFO[window.Property(Duration)] instead of $INFO[ListItem.Duration], but i was wondering if there is a more elegant way to substitute each instance globally hence without altering the base code (don't know if i am crystal clear here ;D ).
Thnaks
@mkortstiege
imo this should be something that is by default available for skins
Well, my first try to realy mod a skin and i already put my finger on big a drawback - if it is not possible.
In my case there are 25 instances of it with conditions long as my arm and a lot of ! conditions. If i need to add another condition it means duplicating the existing ones + creating a lot of new sets for the ! condition... meh oO
Yes you can add it and keep the base code so it can still works even if the script.duration is not installed.
edit 2015-04-24 : Mike_Doc's technique described below on post #11 is very good, i used it on the readme file, no need to manipulate multiple conditions. Thank you Mike !
Hmm thanks, but you still have to duplicate all the references locally which is a pain ... I though of a more global way to do it, but it seems to be impossible Sad
Like a "if controle type has Listitem.Duration AND System.HasAddon(script.duration) then replace Listitem.Duration by window.Property(Duration)"
(2015-04-07, 16:02)Martijn Wrote: [ -> ]@mkortstiege
+1
Like Player.Duration(Format) : http://kodi.wiki/view/InfoLabels#Player_labels
And skinners or Kodi in language settings should just have a centralized setting to choose between duration in minutes and duration with format hh:mm
Maybe in Isengard (or JHuh) Wink
Lost way too much time with 14.2 so this won't be available for 15 (most likely) :/
@twolaw : good job, it work well on library or film information but not on widgets Sad
Hi twolaw,
Thanks for the script, my solution to implementing it into the skin I use is as follows:
1) Created new button 'Aternative Duration' in Skin >> Settings >> General. (AltDuration)
2) Appended the following into variables.xml:
<variable name="MovieDuration">
<value condition="System.HasAddon(script.duration) + Skin.HasSetting(AltDuration)">$INFO[window.Property(Duration)]</value>
<value>$INFO[ListItem.Duration]</value>
</variable>
3) modified MyVideoNav and DialogVideoInfo as per the onload info in readme.
4) Replease Listitem(Duration) wirh $VAR(MovieDuration)
I've only replaced the Listitem in DialogVideoInfo but it all seems to be working fine when switching it on of off.
I'm a noob skinner so I'm sure there may be better ways but this is all I know at the moment.
Mike
I did the same in MQ5 for Helix.
Works like a charm and greatly usefull for movies like The return of the King Extended edition... 4:23 oO !
BTW, would it be possible to have an option to have 4h23 as instead of 4:23 ?
Thanks again
(2015-04-11, 18:57)Namoi Wrote: [ -> ]BTW, would it be possible to have an option to have 4h23 as instead of 4:23 ?
You can do it on line 31 in default.py. Adding an option just for this seems useless in my opinion.
(2015-04-11, 16:24)Mike_Doc Wrote: [ -> ]Hi twolaw,
</variable>
Mike
Yes it looks smart, thanks for sharing !
I'm a noob too, i'm open to suggestions that could improve this addon.
(2015-04-12, 12:22)twolaw Wrote: [ -> ]
Great, that will do it Big Grin
Pages: 1 2 3 4
