2015-03-09, 20:25
More specifically....
I have a Fire TV (not really important to the question) with KODI 14.2... and I have the amber skin set up vertically with a lot of my favorites enabled as the main menu selections.
I have changed the background pictures for each of those main menu selections and that process is a little arduous and takes a bit of time to re-set up after say a system crash or setting up a new fire tv or fire tv stick.... I have the XBMC/KODI backup add on which does its job well for settings and add ons and saving the actual favorites and generic skin....
But it loads into a generic confluence skin and then when you change the skin to amber... it does not save the specific way i have set up the favorites as the main menu or the backgrounds that i have assigned to them... It would be very helpful if someone knew if/where there is a specific file that i can point the back up program to include in its back up process...(i beleive there is a way to add 2 extra paths) or if i can copy that file and just paste it into the new/reinstated set ups....?
Any help would be appreciated...
And side note... Thank you for updating amber to work with KODI!!!
