2015-03-11, 11:30
2015-06-15, 21:39
Really nice skin. Thx a lot, especially for the Plexbmc support
2015-06-24, 20:06
after last update problems with actor info option (no info)
on openelec isengard beta 2
2015-06-24, 21:45
(2015-06-24, 20:06)mastervan Wrote: [ -> ]after last update problems with actor info option (no info)
I confirm. As a workaround, you can access actor info this way: movie -> info -> extended info -> actors -> click on an actor.
It will be fixed for the next release.
Tgx
2015-07-04, 14:23
sorry but i can't delete my post
2015-07-18, 05:56
Question: when adding a timer for a TV guide recording and then clicking "yes" to record, I'm presented with an options menu (as expected) but there are no descriptions to be read? Bug?
2015-07-19, 10:10
(2015-07-18, 05:56)rroos Wrote: [ -> ]Question: when adding a timer for a TV guide recording and then clicking "yes" to record, I'm presented with an options menu (as expected) but there are no descriptions to be read? Bug?
Which pvr addon are you using?
2015-07-19, 10:38
NextPVR
2015-07-19, 10:54
I'm working on it for the next release.
Tgx
Tgx
2015-07-19, 14:02
Cool. Let me know if you need someone to assist in testing.
2015-07-20, 15:45
(2015-07-19, 14:02)rroos Wrote: [ -> ]Cool. Let me know if you need someone to assist in testing.
I've completely revised the support for the NextPVR, WMC, DvbLink pvr clients:
https://github.com/Tgxcorporation/skin.n...a0fbe62505
No more need to rename any file!
You can test it installing the latest version on Github: https://github.com/Tgxcorporation/skin.n...rom-GitHub
Tgx
2015-07-21, 11:13
Thanks! The recording options are now clearly shown. The only remaining issue I have with this is that the 'focus' isn't on the window.
So it works with a mouse, but if you use a remote or keyboard, when you select "add timer", then "yes", and are presented with the recording options, there is no way to use the controls to make changes to the defaults selections or even click "ok". You'll have to revert to a mouse.
2015-07-21, 15:07
2015-07-21, 15:32
Yep, that did it. Awesome! Incredibly fast turnaround - much appreciated!
2015-08-03, 22:27
I just switched to the skin and very much enjoy the look and feel of it. Great Work!
I haven't found an option to rate music with the official "Kore" remote app yet. Is there a way of doing it besides navigating to the full playlist, displaying song information and selecting rating+ or rating-? And if not, is it possible to bind rating+ to "up" and rating- to "down" on the remote while playing music fullscreen?
