i am using Aeon MQ 5 and want to change some thing and didn't find how to do that:
1. How to remove last added movies:
To something like that:
2. How to define my own picture for movies\TV Shows ?
3. How to add grid lines near every movies like in this example:
The recently added movies that show above the main menu is widget and can be switched off in the settings. As to the lins..No idea it may be a MOD of some sort.
1) Settings > Skin Settings > Widgets to turn off. You can’t have the widgets at the top like in MQ4.
2) Settings Sub-menu > Customize main menu > Change background to….
3) That is just one of the views called ‘Right List’.
