2015-03-27, 18:34
I created a video source that contains home videos from multiple paths and add the source to favorite.
I'm able to go to that source by accessing it from favorite. But when I tried to create a custom home menu to go to use that favorite node and accessing it from the home menu it always go to the parent video node.
I've tested with Confluence and Black Glass Nova skins and they all worked. So I think there's something wrong with creating a home menu item from a multipath source.
By the way, I also did the same thing with single path source by adding it to favorite then created a home menu item from favorite and it worked.
So it must be the multipath that's causing the problem.
Also the old Aeon Nox 4 worked fine with multipath too.
Have anyone successfully added a main menu item using multipath source?
I'm currently running Kodi 14.2 RC with Aeon Nox 5 skin
