Full Version: Can't find Skin Re-Touched in repo
Hi All,
I downloaded and installed Helix Kodibuntu fresh from usb.
I hooked up an Elo touchscreen, and wan t to use the re-touched skin.
Unfortunately i cant find it in the skin database. I use the Kodi Add-on repository.
Where can i find a zip file to install via zip? Or can I add it to the repo?
Hope to hear!
Best regards.
You can find a zip file here:
https://github.com/xbmc/skin.re-touched/releases
Max
