Full Version: Pandora ONE - DNS Problem
hi guys
i hope someone can help me with this.
i use the pandora addon from the xbmc repo and pandoki (amazon fire tv, win 7)
My Problem is i cant login when i check Pandora One, in the settings.
i think i narrowed down my problem to the dns service that i use to connect to pandora.
i tried to connect to pandora via a vpn, and it worked,
kodi was able to connect with the Pandora One Checkbox enabled (pandoki + pandora addon 2.3.2)
when i tried to connect the normal way via dns i get the same error message as before,
Error: Login Failed, Bad User/Pass/Proxy (only with pandora one enabled)
i use (trickbyte.com) dns service never had problems, pandora and slacker working fine for me.
i tried some other dns services: (made some free trials)
mediahint, usacess.ca, unblock-us.com
kodi + pandora is working on all of them, but only without the pandora one disabled.
pls help me, this drives me crazy
kodi logs:
pandora addon:
14:51:32 T:1073991712  NOTICE: special://profile/ is mapped to: special://masterprofile/
14:51:32 T:1073991712  NOTICE: -----------------------------------------------------------------------
14:51:32 T:1073991712  NOTICE: Starting Kodi (14.2-RC1 Git:2015-03-11-e7ba06f-dirty). Platform: Android ARM 32-bit
14:51:32 T:1073991712  NOTICE: Using Release Kodi x32 build
14:51:32 T:1073991712  NOTICE: Kodi compiled Mar 11 2015 by GCC 4.8.0 for Android ARM 32-bit API level 14 (API level 14)
14:51:32 T:1073991712  NOTICE: Running on Amazon AFTB with Android 4.2.2 API level 17, kernel: Linux ARM 32-bit version 3.4.0-perf-g21e3850
14:51:32 T:1073991712  NOTICE: FFmpeg version: 14.2b1-Helix-39-ge7ba06f-xbmc-2.4.6-Helix
14:51:32 T:1073991712  NOTICE: Host CPU: ARMv7 Processor rev 0 (v7l), 4 cores available
14:51:32 T:1073991712  NOTICE: Product: bueller, Device: bueller, Board: MSM8960 - Manufacturer: Amazon, Brand: qcom, Model: AFTB, Hardware: qcom
14:51:32 T:1073991712  NOTICE: ARM Features: Neon enabled
14:51:32 T:1073991712  NOTICE: special://xbmc/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
14:51:32 T:1073991712  NOTICE: special://xbmcbin/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
14:51:32 T:1073991712  NOTICE: special://masterprofile/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata
14:51:32 T:1073991712  NOTICE: special://home/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi
14:51:32 T:1073991712  NOTICE: special://temp/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
14:51:32 T:1073991712  NOTICE: The executable running is:
14:51:32 T:1073991712  NOTICE: Local hostname: localhost
14:51:32 T:1073991712  NOTICE: Log File is located: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp/kodi.log
14:51:32 T:1073991712  NOTICE: load settings...
14:51:32 T:1073991712   DEBUG: static int CAndroidFeatures::GetVersion(): android.os.Build.VERSION 17
14:51:32 T:1073991712   DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
14:51:32 T:1073991712 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
14:51:32 T:1073991712   DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/android.xml
14:51:32 T:1073991712  NOTICE: Found 1 Lists of Devices
14:51:32 T:1073991712  NOTICE: Enumerated AUDIOTRACK devices:
14:51:32 T:1073991712  NOTICE:     Device 1
14:51:32 T:1073991712  NOTICE:         m_deviceName      : AudioTrack
14:51:32 T:1073991712  NOTICE:         m_displayName     : android
14:51:32 T:1073991712  NOTICE:         m_displayNameExtra: audiotrack
14:51:32 T:1073991712  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
14:51:32 T:1073991712  NOTICE:         m_channels        : FL,FR,FC,LFE,BL,BR
14:51:32 T:1073991712  NOTICE:         m_sampleRates     : 48000
14:51:32 T:1073991712  NOTICE:         m_dataFormats     : AE_FMT_S16LE,AE_FMT_AC3,AE_FMT_DTS
14:51:32 T:1073991712  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
14:51:32 T:1073991712  NOTICE: Loaded settings file from special://profile/advancedsettings.xml
14:51:32 T:1073991712  NOTICE: Contents of special://profile/advancedsettings.xml are...
                                            <!-- zerocache -->
                                            <advancedsettings>
                                              <network>
                                                <cachemembuffersize>0</cachemembuffersize>
                                                <curlclienttimeout>45</curlclienttimeout>
                                              </network>
                                              <gui>
                                                <algorithmdirtyregions>3</algorithmdirtyregions>
                                                <nofliptimeout>0</nofliptimeout>
                                              </gui>
                                              <videoscanner>
                                                <ignoreerrors>true</ignoreerrors>
                                              </videoscanner>
                                            </advancedsettings>
14:51:32 T:1073991712  NOTICE: Default DVD Player: dvdplayer
14:51:32 T:1073991712  NOTICE: Default Video Player: dvdplayer
14:51:32 T:1073991712  NOTICE: Default Audio Player: paplayer
14:51:32 T:1073991712  NOTICE: Disabled debug logging due to GUI setting. Level 0.
14:51:32 T:1073991712  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
14:51:32 T:1073991712  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
14:51:32 T:1073991712  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
14:51:32 T:1073991712  NOTICE: Loaded playercorefactory configuration
14:51:32 T:1073991712  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
14:51:32 T:1073991712  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
14:51:32 T:1461112024  NOTICE: Thread ActiveAE start, auto delete: false
14:51:32 T:1461002320  NOTICE: Thread AESink start, auto delete: false
14:51:32 T:1073991712  NOTICE: Running database version Addons16
14:51:33 T:1073991712  NOTICE: ADDONS: Using repository repository.gomioa
14:51:33 T:1073991712  NOTICE: ADDONS: Using repository repository.tknorris.release
14:51:33 T:1073991712  NOTICE: ADDONS: Using repository repo.hybrid
14:51:33 T:1073991712  NOTICE: ADDONS: Using repository repository.xunitytalk
14:51:33 T:1073991712  NOTICE: ADDONS: Using repository repository.Kinkin
14:51:33 T:1073991712  NOTICE: ADDONS: Using repository net.rieter.xot.repository
14:51:33 T:1073991712  NOTICE: ADDONS: Using repository repository.iptvxtra
14:51:33 T:1073991712  NOTICE: ADDONS: Using repository repository.xstream
14:51:33 T:1073991712  NOTICE: ADDONS: Using repository repository.xbmchub
14:51:33 T:1073991712  NOTICE: ADDONS: Using repository repository.xbmc.org
14:51:33 T:1073991712  NOTICE: ADDONS: Using repository repository.spoyser
14:51:33 T:1073991712  NOTICE: ADDONS: Using repository repository.xbmc-israel
14:51:33 T:1073991712  NOTICE: ADDONS: Using repository repository.MaxMustermann.xbmc
14:51:33 T:1073991712  NOTICE: ADDONS: Using repository repository.lambda
14:51:33 T:1073991712  NOTICE: ADDONS: Using repository repository.BlazeRepo
14:51:33 T:1073991712  NOTICE: ADDONS: Using repository repository.k3oni.xbmc
14:51:33 T:1073991712  NOTICE: ADDONS: Using repository repository.superrepo.org.helix.all
14:51:33 T:1073991712  NOTICE: ADDONS: Using repository repository.totalinstaller
14:51:33 T:1073991712 WARNING: Unable to resolve: /libcec.so CECInitialise, reason: Symbol not found:
14:51:33 T:1073991712   ERROR: Unable to resolve exports from dll libcec.so
14:51:33 T:1073991712   ERROR: virtual void PERIPHERALS::CPeripherals::Initialise() - failed to initialise bus cec
14:51:33 T:1462081216  NOTICE: Thread PeripBusUSB start, auto delete: false
14:51:33 T:1073991712  NOTICE: virtual bool CWinSystemEGL::InitWindowSystem(): Using EGL Implementation: android
14:51:33 T:1073991712  NOTICE: Current resolution: 1920x1080 @ 60.00 - Full Screen
14:51:33 T:1073991712  NOTICE: Previous line repeats 1 times.
14:51:33 T:1073991712  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
14:51:33 T:1073991712  NOTICE: Found ([email protected]) at 16, setting to RES_DESKTOP at 16
14:51:33 T:1073991712  NOTICE: Checking resolution 16
14:51:33 T:1073991712  NOTICE: GL_VENDOR = Qualcomm
14:51:33 T:1073991712  NOTICE: GL_RENDERER = Adreno (TM) 320
14:51:33 T:1073991712  NOTICE: GL_VERSION = OpenGL ES 3.0 [email protected] [email protected] PDAVID_AU_LINUX_ANDROID_JB_2.5.4.04.02.02.073.175+PATCH[ES]_msm8960_JB_2.5.4_CL3406509_release_ENGG (CL@3406509)
14:51:33 T:1073991712  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.00
14:51:33 T:1073991712  NOTICE: GL_EXTENSIONS = GL_AMD_compressed_ATC_texture GL_AMD_performance_monitor GL_AMD_program_binary_Z400 GL_EXT_debug_labelGL_EXT_debug_markerGL_EXT_robustness GL_EXT_texture_format_BGRA8888 GL_EXT_texture_type_2_10_10_10_REV GL_NV_fence GL_OES_compressed_ETC1_RGB8_texture GL_OES_depth_texture GL_OES_depth24 GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_fragment_precision_high GL_OES_get_program_binary GL_OES_packed_depth_stencil GL_OES_depth_texture_cube_map GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_texture_3D GL_OES_texture_float GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_vertex_half_float GL_OES_vertex_type_10_10_10_2 GL_OES_vertex_array_object GL_QCOM_alpha_test GL_QCOM_binning_control GL_QCOM_driver_control GL_QCOM_perfmon_global_mode GL_QCOM_extended_get GL_QCOM_extended_get2 GL_QCOM_tiled_rendering GL_QCOM_writeonly_rendering GL_EXT_sRGB GL_EXT_texture_filter_anisotropic GL_EXT_color_buffer_float GL_EXT_color_buffer_half_float
14:51:33 T:1073991712  NOTICE: No Joystick name specified, loading default map
14:51:33 T:1073991712  NOTICE: Previous line repeats 36 times.
14:51:33 T:1073991712  NOTICE: Running database version Addons16
14:51:33 T:1073991712  NOTICE: Running database version ViewModes6
14:51:33 T:1073991712  NOTICE: Running database version Textures13
14:51:33 T:1073991712  NOTICE: Running database version MyMusic48
14:51:33 T:1073991712  NOTICE: Running database version MyVideos90
14:51:33 T:1073991712  NOTICE: Running database version TV26
14:51:33 T:1073991712  NOTICE: Running database version Epg8
14:51:34 T:1073991712  NOTICE: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/skin.eminence/sounds/sounds.xml, Line 0
                                            Failed to open file
14:51:34 T:1073991712 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
14:51:34 T:1073991712 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
14:51:34 T:1073991712 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
14:51:34 T:1073991712 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
14:51:34 T:1517721456  NOTICE: Thread LanguageInvoker start, auto delete: false
14:51:34 T:1073991712  NOTICE: Previous line repeats 7 times.
14:51:34 T:1073991712  NOTICE: void CApplication::UpdateLibraries(): Starting video library startup scan
14:51:35 T:1519514728  NOTICE: Thread VideoInfoScanner start, auto delete: false
14:51:35 T:1519473088  NOTICE: Thread LanguageInvoker start, auto delete: false
14:51:35 T:1073991712  NOTICE: initialize done
14:51:35 T:1073991712  NOTICE: Running the application...
14:51:35 T:1521088936  NOTICE: Thread LanguageInvoker start, auto delete: false
14:51:35 T:1522076344  NOTICE: Previous line repeats 5 times.
14:51:35 T:1522076344  NOTICE: Thread JobWorker start, auto delete: true
14:51:35 T:1073991712  NOTICE: Previous line repeats 2 times.
14:51:35 T:1073991712  NOTICE: starting zeroconf publishing
14:51:35 T:1073991712  NOTICE: Webserver: Starting...
14:51:35 T:1073991712  NOTICE: WebServer: Started the webserver
14:51:35 T:1073991712  NOTICE: starting upnp controller
14:51:35 T:1073991712  NOTICE: starting upnp server
14:51:35 T:1521656944  NOTICE: Thread ZerocconfEmbedded start, auto delete: false
14:51:35 T:1073991712  NOTICE: starting upnp renderer
14:51:35 T:1073991712  NOTICE: ES: Starting event server
14:51:35 T:1073991712  NOTICE: Current resolution: 1920x1080 @ 60.00 - Full Screen
14:51:35 T:1073991712  NOTICE: GL_VENDOR = Qualcomm
14:51:35 T:1073991712  NOTICE: GL_RENDERER = Adreno (TM) 320
14:51:35 T:1073991712  NOTICE: GL_VERSION = OpenGL ES 3.0 [email protected] [email protected] PDAVID_AU_LINUX_ANDROID_JB_2.5.4.04.02.02.073.175+PATCH[ES]_msm8960_JB_2.5.4_CL3406509_release_ENGG (CL@3406509)
14:51:35 T:1073991712  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.00
14:51:35 T:1073991712  NOTICE: GL_EXTENSIONS = GL_AMD_compressed_ATC_texture GL_AMD_performance_monitor GL_AMD_program_binary_Z400 GL_EXT_debug_labelGL_EXT_debug_markerGL_EXT_robustness GL_EXT_texture_format_BGRA8888 GL_EXT_texture_type_2_10_10_10_REV GL_NV_fence GL_OES_compressed_ETC1_RGB8_texture GL_OES_depth_texture GL_OES_depth24 GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_fragment_precision_high GL_OES_get_program_binary GL_OES_packed_depth_stencil GL_OES_depth_texture_cube_map GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_texture_3D GL_OES_texture_float GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_vertex_half_float GL_OES_vertex_type_10_10_10_2 GL_OES_vertex_array_object GL_QCOM_alpha_test GL_QCOM_binning_control GL_QCOM_driver_control GL_QCOM_perfmon_global_mode GL_QCOM_extended_get GL_QCOM_extended_get2 GL_QCOM_tiled_rendering GL_QCOM_writeonly_rendering GL_EXT_sRGB GL_EXT_texture_filter_anisotropic GL_EXT_color_buffer_float GL_EXT_color_buffer_half_float
14:51:35 T:1533912928  NOTICE: Thread TCPServer start, auto delete: false
14:51:35 T:1524088392  NOTICE: Thread EventServer start, auto delete: false
14:51:35 T:1524088392  NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
14:51:35 T:1524088392  NOTICE: UDP: Listening on port 9777
14:51:35 T:1517721456  NOTICE: -->Python Interpreter Initialized<--
14:51:35 T:1519514728  NOTICE: Previous line repeats 1 times.
14:51:35 T:1519514728  NOTICE: VideoInfoScanner: Starting scan ..
14:51:35 T:1521129976  NOTICE: -->Python Interpreter Initialized<--
14:51:36 T:1536219568  NOTICE: Previous line repeats 7 times.
14:51:36 T:1536219568  NOTICE: Thread LanguageInvoker start, auto delete: false
14:51:36 T:1518022008  NOTICE: Previous line repeats 1 times.
14:51:36 T:1518022008  NOTICE: -->Python Interpreter Initialized<--
14:51:37 T:1518000776  NOTICE: Previous line repeats 1 times.
14:51:37 T:1518000776  NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting background proc (6.0.13)
14:51:38 T:1519514728  NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:02
14:51:38 T:1521153168  NOTICE: -->Python Interpreter Initialized<--
14:51:39 T:1518022008  NOTICE: Previous line repeats 3 times.
14:51:39 T:1518022008  NOTICE: titan helper version 1.6.7 started
14:51:39 T:1521153168  NOTICE: [Flixanity] Subscription service starting...
14:51:39 T:1521129976  NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting background proc (6.0.13)
14:51:39 T:1523523240  NOTICE: -->Python Interpreter Initialized<--
14:51:39 T:1514226880  NOTICE: script.grab.fanart: Grab Fanart Service Started
14:51:41 T:1521129976  NOTICE: script.tv.show.next.aired: ### exiting this duplicate background-proc (skin vs service)
14:51:42 T:1521088936  NOTICE: 1Channel: Service: Installed Version: 2.5.64
14:51:43 T:1521088936  NOTICE: 1Channel: Loading sqlite3 as DB engine
14:51:43 T:1521088936  NOTICE: 1Channel: Service: Resetting...
14:51:43 T:1521088936  NOTICE: 1Channel: Service: starting...
14:51:43 T:1519293040  NOTICE:  StorageServer Module loaded RUN
14:51:43 T:1519293040  NOTICE: StorageClient-2.5.4 Starting server
14:51:44 T:1519476632  NOTICE: http://tribeca.tvaddons.ag/tools/notifications/news.txt
14:51:44 T:1519476632  NOTICE: ['notifications-on-startup', False, 'DoFromService', True]
14:51:44 T:1519476632  NOTICE: ['OLD', 't', '2', 'We just wanted to remind you that there\xe2\x80\x99s a new and improved version of XBMC\navailable which we highly recommend upgrading to as soon as possible. It\noffers enhanced hardware decoding along with a ton of other fixes. [B]It\xe2\x80\x99s not\neven called XBMC anymore[/B]; it\xe2\x80\x99s now called [COLOR white]Kodi[/COLOR], need we say more?\n\nWe\xe2\x80\x99ve put together some very simple, newbie friendly guides which will walk\nyou through every step of the way. Please visit the following page for\nmore information: [B][COLOR white]www.tvaddons.ag/update-kodi[/COLOR][/B]\n\nThank you very much for your support. We hope you continue to enjoy our\naddons far into the future, it\xe2\x80\x99s only going to get better from here!']
14:51:44 T:1519476632  NOTICE: ['NEW', 't', '2', 'We just wanted to remind you that there\xe2\x80\x99s a new and improved version of XBMC\navailable which we highly recommend upgrading to as soon as possible. It\noffers enhanced hardware decoding along with a ton of other fixes. [B]It\xe2\x80\x99s not\neven called XBMC anymore[/B]; it\xe2\x80\x99s now called [COLOR white]Kodi[/COLOR], need we say more?\n\nWe\xe2\x80\x99ve put together some very simple, newbie friendly guides which will walk\nyou through every step of the way. Please visit the following page for\nmore information: [B][COLOR white]www.tvaddons.ag/update-kodi[/COLOR][/B]\n\nThank you very much for your support. We hope you continue to enjoy our\naddons far into the future, it\xe2\x80\x99s only going to get better from here!']
14:51:45 T:1523523240  NOTICE: CommonFunctions-2.5.1
14:52:47 T:1534818208  NOTICE: Thread JobWorker start, auto delete: true
14:53:26 T:1761073192  NOTICE: Thread LanguageInvoker start, auto delete: false
14:53:26 T:1761073192  NOTICE: -->Python Interpreter Initialized<--
14:53:26 T:1761073192  NOTICE: Pandora: Initializing v2.3.2
14:53:26 T:1761073192  NOTICE: Pandora: sys.platform = linux3
14:53:28 T:1761073192   ERROR: ERROR:root:Network error: <urlopen error [Errno 8] _ssl.c:480: EOF occurred in violation of protocol>
14:53:28 T:1761073192  NOTICE: .
pandoki:
20:16:40 T:1548556032  NOTICE: special://profile/ is mapped to: special://masterprofile/
20:16:40 T:1548556032  NOTICE: -----------------------------------------------------------------------
20:16:40 T:1548556032  NOTICE: Starting Kodi (14.2-RC1 Git:2015-03-11-e7ba06f-dirty). Platform: Android ARM 32-bit
20:16:40 T:1548556032  NOTICE: Using Release Kodi x32 build
20:16:40 T:1548556032  NOTICE: Kodi compiled Mar 11 2015 by GCC 4.8.0 for Android ARM 32-bit API level 14 (API level 14)
20:16:40 T:1548556032  NOTICE: Running on Amazon AFTB with Android 4.2.2 API level 17, kernel: Linux ARM 32-bit version 3.4.0-perf-g21e3850
20:16:40 T:1548556032  NOTICE: FFmpeg version: 14.2b1-Helix-39-ge7ba06f-xbmc-2.4.6-Helix
20:16:40 T:1548556032  NOTICE: Host CPU: ARMv7 Processor rev 0 (v7l), 4 cores available
20:16:40 T:1548556032  NOTICE: Product: bueller, Device: bueller, Board: MSM8960 - Manufacturer: Amazon, Brand: qcom, Model: AFTB, Hardware: qcom
20:16:40 T:1548556032  NOTICE: ARM Features: Neon enabled
20:16:40 T:1548556032  NOTICE: special://xbmc/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
20:16:40 T:1548556032  NOTICE: special://xbmcbin/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
20:16:40 T:1548556032  NOTICE: special://masterprofile/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata
20:16:40 T:1548556032  NOTICE: special://home/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi
20:16:40 T:1548556032  NOTICE: special://temp/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
20:16:40 T:1548556032  NOTICE: The executable running is:
20:16:40 T:1548556032  NOTICE: Local hostname: localhost
20:16:40 T:1548556032  NOTICE: Log File is located: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp/kodi.log
20:16:40 T:1548556032  NOTICE: load settings...
20:16:40 T:1548556032   DEBUG: static int CAndroidFeatures::GetVersion(): android.os.Build.VERSION 17
20:16:40 T:1548556032   DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
20:16:40 T:1548556032 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
20:16:40 T:1548556032   DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/android.xml
20:16:40 T:1548556032  NOTICE: Found 1 Lists of Devices
20:16:40 T:1548556032  NOTICE: Enumerated AUDIOTRACK devices:
20:16:40 T:1548556032  NOTICE:     Device 1
20:16:40 T:1548556032  NOTICE:         m_deviceName      : AudioTrack
20:16:40 T:1548556032  NOTICE:         m_displayName     : android
20:16:40 T:1548556032  NOTICE:         m_displayNameExtra: audiotrack
20:16:40 T:1548556032  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
20:16:40 T:1548556032  NOTICE:         m_channels        : FL,FR,FC,LFE,BL,BR
20:16:40 T:1548556032  NOTICE:         m_sampleRates     : 48000
20:16:40 T:1548556032  NOTICE:         m_dataFormats     : AE_FMT_S16LE,AE_FMT_AC3,AE_FMT_DTS
20:16:40 T:1548556032  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
20:16:40 T:1548556032  NOTICE: Loaded settings file from special://profile/advancedsettings.xml
20:16:40 T:1548556032  NOTICE: Contents of special://profile/advancedsettings.xml are...
                                            <!-- zerocache -->
                                            <advancedsettings>
                                              <network>
                                              </network>
                                              <gui>
                                              </gui>
                                              <videoscanner>
                                              </videoscanner>
                                            </advancedsettings>
20:16:40 T:1548556032  NOTICE: Default DVD Player: dvdplayer
20:16:40 T:1548556032  NOTICE: Default Video Player: dvdplayer
20:16:40 T:1548556032  NOTICE: Default Audio Player: paplayer
20:16:40 T:1548556032  NOTICE: Disabled debug logging due to GUI setting. Level 0.
20:16:40 T:1548556032  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
20:16:40 T:1548556032  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
20:16:40 T:1548556032  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
20:16:40 T:1548556032  NOTICE: Loaded playercorefactory configuration
20:16:40 T:1548556032  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
20:16:40 T:1548556032  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
20:16:40 T:1552316752  NOTICE: Thread ActiveAE start, auto delete: false
20:16:40 T:1554612328  NOTICE: Thread AESink start, auto delete: false
20:16:40 T:1548556032  NOTICE: Running database version Addons16
20:16:41 T:1548556032  NOTICE: ADDONS: Using repository repository.gomioa
20:16:41 T:1548556032  NOTICE: ADDONS: Using repository repository.xbmc.org
20:16:41 T:1548556032  NOTICE: ADDONS: Using repository repository.spoyser
20:16:41 T:1548556032  NOTICE: ADDONS: Using repository repository.xbmc-israel
20:16:41 T:1548556032  NOTICE: ADDONS: Using repository repository.tknorris.release
20:16:41 T:1548556032  NOTICE: ADDONS: Using repository repo.hybrid
20:16:41 T:1548556032  NOTICE: ADDONS: Using repository repository.xunitytalk
20:16:41 T:1548556032  NOTICE: ADDONS: Using repository net.rieter.xot.repository
20:16:41 T:1548556032  NOTICE: ADDONS: Using repository repository.lambda
20:16:41 T:1548556032  NOTICE: ADDONS: Using repository repository.Kinkin
20:16:41 T:1548556032  NOTICE: ADDONS: Using repository repository.xbmchub
20:16:41 T:1548556032  NOTICE: ADDONS: Using repository repository.BlazeRepo
20:16:41 T:1548556032  NOTICE: ADDONS: Using repository repository.k3oni.xbmc
20:16:41 T:1548556032  NOTICE: ADDONS: Using repository repository.totalinstaller
20:16:41 T:1548556032 WARNING: Unable to resolve: /libcec.so CECInitialise, reason: Symbol not found:
20:16:41 T:1548556032   ERROR: Unable to resolve exports from dll libcec.so
20:16:41 T:1548556032   ERROR: virtual void PERIPHERALS::CPeripherals::Initialise() - failed to initialise bus cec
20:16:41 T:1555442248  NOTICE: Thread PeripBusUSB start, auto delete: false
20:16:41 T:1548556032  NOTICE: virtual bool CWinSystemEGL::InitWindowSystem(): Using EGL Implementation: android
20:16:41 T:1548556032  NOTICE: Current resolution: 1920x1080 @ 60.00 - Full Screen
20:16:41 T:1548556032  NOTICE: Previous line repeats 1 times.
20:16:41 T:1548556032  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
20:16:41 T:1548556032  NOTICE: Found ([email protected]) at 16, setting to RES_DESKTOP at 16
20:16:41 T:1548556032  NOTICE: Checking resolution 16
20:16:41 T:1548556032  NOTICE: GL_VENDOR = Qualcomm
20:16:41 T:1548556032  NOTICE: GL_RENDERER = Adreno (TM) 320
20:16:41 T:1548556032  NOTICE: GL_VERSION = OpenGL ES 3.0 [email protected] [email protected] PDAVID_AU_LINUX_ANDROID_JB_2.5.4.04.02.02.073.175+PATCH[ES]_msm8960_JB_2.5.4_CL3406509_release_ENGG (CL@3406509)
20:16:41 T:1548556032  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.00
20:16:41 T:1548556032  NOTICE: GL_EXTENSIONS = GL_AMD_compressed_ATC_texture GL_AMD_performance_monitor GL_AMD_program_binary_Z400 GL_EXT_debug_labelGL_EXT_debug_markerGL_EXT_robustness GL_EXT_texture_format_BGRA8888 GL_EXT_texture_type_2_10_10_10_REV GL_NV_fence GL_OES_compressed_ETC1_RGB8_texture GL_OES_depth_texture GL_OES_depth24 GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_fragment_precision_high GL_OES_get_program_binary GL_OES_packed_depth_stencil GL_OES_depth_texture_cube_map GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_texture_3D GL_OES_texture_float GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_vertex_half_float GL_OES_vertex_type_10_10_10_2 GL_OES_vertex_array_object GL_QCOM_alpha_test GL_QCOM_binning_control GL_QCOM_driver_control GL_QCOM_perfmon_global_mode GL_QCOM_extended_get GL_QCOM_extended_get2 GL_QCOM_tiled_rendering GL_QCOM_writeonly_rendering GL_EXT_sRGB GL_EXT_texture_filter_anisotropic GL_EXT_color_buffer_float GL_EXT_color_buffer_half_float
20:16:41 T:1548556032  NOTICE: No Joystick name specified, loading default map
20:16:41 T:1548556032  NOTICE: Previous line repeats 36 times.
20:16:41 T:1548556032  NOTICE: Running database version Addons16
20:16:41 T:1548556032  NOTICE: Running database version ViewModes6
20:16:41 T:1548556032  NOTICE: Running database version Textures13
20:16:41 T:1548556032  NOTICE: Running database version MyMusic48
20:16:41 T:1548556032  NOTICE: Running database version MyVideos90
20:16:41 T:1548556032  NOTICE: Running database version TV26
20:16:41 T:1548556032  NOTICE: Running database version Epg8
20:16:42 T:1548556032 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
20:16:42 T:1548556032 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
20:16:42 T:1548556032 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
20:16:42 T:1548556032 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
20:16:42 T:1568456104  NOTICE: Thread LanguageInvoker start, auto delete: false
20:16:42 T:1548556032  NOTICE: Previous line repeats 3 times.
20:16:42 T:1548556032  NOTICE: void CApplication::UpdateLibraries(): Starting video library startup scan
20:16:42 T:1570320528  NOTICE: Thread VideoInfoScanner start, auto delete: false
20:16:42 T:1569333256  NOTICE: Thread LanguageInvoker start, auto delete: false
20:16:42 T:1548556032  NOTICE: Previous line repeats 2 times.
20:16:42 T:1548556032  NOTICE: initialize done
20:16:42 T:1548556032  NOTICE: Running the application...
20:16:42 T:1569316328  NOTICE: Thread LanguageInvoker start, auto delete: false
20:16:42 T:1568456104  NOTICE: -->Python Interpreter Initialized<--
20:16:43 T:1575961560  NOTICE: Previous line repeats 1 times.
20:16:43 T:1575961560  NOTICE: Thread JobWorker start, auto delete: true
20:16:43 T:1569182360  NOTICE: -->Python Interpreter Initialized<--
20:16:43 T:1548556032  NOTICE: starting zeroconf publishing
20:16:43 T:1576702392  NOTICE: Thread ZerocconfEmbedded start, auto delete: false
20:16:43 T:1548556032  NOTICE: Webserver: Starting...
20:16:43 T:1548556032  NOTICE: WebServer: Started the webserver
20:16:43 T:1548556032  NOTICE: starting upnp controller
20:16:43 T:1576300160  NOTICE: Thread JobWorker start, auto delete: true
20:16:43 T:1548556032  NOTICE: starting upnp server
20:16:43 T:1548556032  NOTICE: starting upnp renderer
20:16:43 T:1568478800  NOTICE: -->Python Interpreter Initialized<--
20:16:43 T:1548556032  NOTICE: ES: Starting event server
20:16:43 T:1576019096  NOTICE: Thread EventServer start, auto delete: false
20:16:43 T:1576019096  NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
20:16:43 T:1576017096  NOTICE: Thread TCPServer start, auto delete: false
20:16:43 T:1576019096  NOTICE: UDP: Listening on port 9777
20:16:43 T:1548556032  NOTICE: Current resolution: 1920x1080 @ 60.00 - Full Screen
20:16:43 T:1548556032  NOTICE: GL_VENDOR = Qualcomm
20:16:43 T:1548556032  NOTICE: GL_RENDERER = Adreno (TM) 320
20:16:43 T:1548556032  NOTICE: GL_VERSION = OpenGL ES 3.0 [email protected] [email protected] PDAVID_AU_LINUX_ANDROID_JB_2.5.4.04.02.02.073.175+PATCH[ES]_msm8960_JB_2.5.4_CL3406509_release_ENGG (CL@3406509)
20:16:43 T:1548556032  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.00
20:16:43 T:1548556032  NOTICE: GL_EXTENSIONS = GL_AMD_compressed_ATC_texture GL_AMD_performance_monitor GL_AMD_program_binary_Z400 GL_EXT_debug_labelGL_EXT_debug_markerGL_EXT_robustness GL_EXT_texture_format_BGRA8888 GL_EXT_texture_type_2_10_10_10_REV GL_NV_fence GL_OES_compressed_ETC1_RGB8_texture GL_OES_depth_texture GL_OES_depth24 GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_fragment_precision_high GL_OES_get_program_binary GL_OES_packed_depth_stencil GL_OES_depth_texture_cube_map GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_texture_3D GL_OES_texture_float GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_vertex_half_float GL_OES_vertex_type_10_10_10_2 GL_OES_vertex_array_object GL_QCOM_alpha_test GL_QCOM_binning_control GL_QCOM_driver_control GL_QCOM_perfmon_global_mode GL_QCOM_extended_get GL_QCOM_extended_get2 GL_QCOM_tiled_rendering GL_QCOM_writeonly_rendering GL_EXT_sRGB GL_EXT_texture_filter_anisotropic GL_EXT_color_buffer_float GL_EXT_color_buffer_half_float
20:16:43 T:1570320528  NOTICE: VideoInfoScanner: Starting scan ..
20:16:43 T:1578343872  NOTICE: Thread JobWorker start, auto delete: true
20:16:43 T:1707064296  NOTICE: Previous line repeats 1 times.
20:16:43 T:1707064296  NOTICE: Thread LanguageInvoker start, auto delete: false
20:16:43 T:1569316328  NOTICE: -->Python Interpreter Initialized<--
20:16:43 T:1724191504  NOTICE: Previous line repeats 2 times.
20:16:43 T:1724191504  NOTICE: Thread LanguageInvoker start, auto delete: false
20:16:45 T:1707064296  NOTICE: -->Python Interpreter Initialized<--
20:16:45 T:1569350344  NOTICE: [Flixanity] Subscription service starting...
20:16:45 T:1568480744  NOTICE: -->Python Interpreter Initialized<--
20:16:46 T:1570320528  NOTICE: Previous line repeats 1 times.
20:16:46 T:1570320528  NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:03
20:16:48 T:1569333256  NOTICE: 1Channel: Service: Installed Version: 2.5.64
20:16:48 T:1569333256  NOTICE: 1Channel: Loading sqlite3 as DB engine
20:16:48 T:1569333256  NOTICE: 1Channel: Service: Resetting...
20:16:48 T:1569333256  NOTICE: 1Channel: Service: starting...
20:16:49 T:1723851096  NOTICE: Thread LanguageInvoker start, auto delete: false
20:16:49 T:1724191504  NOTICE: CommonFunctions-2.5.1
20:16:50 T:1723851096  NOTICE: -->Python Interpreter Initialized<--
20:16:55 T:1723851096   ERROR: ERROR:root:Network error: <urlopen error [Errno 8] _ssl.c:480: EOF occurred in violation of protocol>
20:16:55 T:1723851096  NOTICE: .
20:16:55 T:1723851096  NOTICE: plugin.audio.pandoki Auth BAD
Solved it,
finally i found a DNS Service which is working --> unlocator.com
i have no idea whats the diffrence to the other services, but this one is working for me.
would be interesting where the problem was.
