(2015-10-20, 10:20)oldpoem Wrote: [ -> ] (2015-10-20, 10:10)gotham_x Wrote: [ -> ]Excuse my ignorance, in various posts Thread read this filter Lentoid for HEVC.
I ask, maybe to many more may seem like a trivial question, where you can 'download this filter Lentoid for HEVC, and on which .xml file
you must configure, is a standard configuration?
In the guide, it seems that there is no reference to this subject.
It can be found at http://www.xhevc.com
You need to use Filtersconfig / Mediaconfig to be able to use anything not defined in internal filters preset. Internal filters is a simplified preset for those does not need anything beside LAVFilters / XySubfilter. But if you want to use something else you need to go Change filters management from internal filters to Media rules & Filters configuration.
Actually it has been the way of using DSPlayer. Internal filters by aracnoz was introduced to be more friendlier with someone new with DSPlayer.
Thanks for the reference, If I do not say nonsense, first you have to download only HEVC / H.265 decoder, and install x86.
Then, create file Filtersconfig / Mediaconfig and save them within userdata and / or DSPlayer?
These scripts must be created as ?
Are script is standardized for both files Filtersconfig / Mediaconfig .xml ?
Finally finished this job you create rules in the GUI DSPlayer -> Filters Interior ?
This example script for Filtersconfig / Mediaconfig, I ask, this script would be fine for both files Filtersconfig / Mediaconfig.xml ?
<mediasconfig>
<rules>
<rule filename=".*h265.*">
<source filter="lavsource_internal" />
<splitter filter="lavsplitter_internal" />
<video filter="lentoid_hevc_decoder" />
<audio filter="lavaudio_internal" />
<subs filter="xysubfilter_internal" />
</rule>
<rule filetypes="mkv|avi|divx|ogm|mp4|mov|m4v|flv|m2v|mpeg|mpg|mts|m2ts|vob|bdmv">
<video filter="lavvideo_internal" />
</rule>
</rules>
I hope I made it clear, is a step by step I need ...
Thanhs.
