If I understand your broken english correctly, yes.
The steps is like these.
1. Download and install filter x86 vesion.
2. Under Dsplayer - Filters Management - change to media & filters rules configuration.
3. Adding filter , select lentoid from system filter list. declared it as video decoder filter. Enter other required information if needed.
4. Under media rules create new rule. Add necessary rules.
DSplayer would automatically create filtersconfig.xml / mediaconfig.xml in userdata folder.
No need to create or edit any xml manually.
Are you sure that the filename thing is necessary? If the video is in the db, we should be able to use videocodec value, shouldn't we?
(2015-10-20, 14:53)ashlar Wrote: [ -> ]Are you sure that the filename thing is necessary? If the video is in the db, we should be able to use videocodec value, shouldn't we?
Have you tried? Because as far as I tried to use defined rule as codec h265 or hevc it didn't work.
(2015-10-20, 14:59)oldpoem Wrote: [ -> ] (2015-10-20, 14:53)ashlar Wrote: [ -> ]Are you sure that the filename thing is necessary? If the video is in the db, we should be able to use videocodec value, shouldn't we?
No, I haven't. If it doesn't work it should be notified to devs, as there's no reason for it not working if older codecs do work.
(2015-10-20, 14:31)oldpoem Wrote: [ -> ]If I understand your broken english correctly, yes.
Exemplary explanation, now it's up to me to put in practice this is the first time that I add filters through the GUI DSPlayer, I read you the passage in the guide Warner, but never put into practice.
Thanks again.
(2015-10-20, 15:05)ashlar Wrote: [ -> ]No, I haven't. If it doesn't work it should be notified to devs, as there's no reason for it not working if older codecs do work.
Maybe aracnoz can look into this h265 / hevc string issue and can tell what exact rule to be defined. But for now filename rule is working solution.
To install the filter Lentoid HEVC / H.265 decoder, which version is recommended for DSPlayer - Double click on reg.bat and / or reg64.bat, my system is 64Bit
Anyone else experiencing issues with the rendering of 'forced' subtitles. Successful display seems particularly random. I have several files which work correctly and others which don't - there is no pattern to it at all. I am presently using 'internal filters' and have attached a log from a file that I know has a 'forced' subtitle header, but which point blank refuses to render. This is a fairly recent addition, so I'm not sure if the others in my collection are working because they have been played previously with a working version - sure I read somewhere that playback states were retained.
Using the Isengard 15.2 DX11 build from the 1st post.
I have also added the media info from the actual file showing the header confirmation
http://pastebin.com/Xv5tGtAd
General
Unique ID : 288888596867825366422622437821868317666 (0xD955EB8087E8756F47FC4F0F7BD29BE2)
Complete name : Z:\Videos\Movies\Angels and Demons (2009)\Angels & Demons (2009).mkv
Format : Matroska
Format version : Version 2
File size : 36.0 GiB
Duration : 2h 18mn
Overall bit rate mode : Variable
Overall bit rate : 37.2 Mbps
Movie name : Angels & Demons (2009)
Encoded date : UTC 2015-10-17 15:06:09
Writing application : MakeMKV v1.9.6 win(x86-release)
Writing library : libmakemkv v1.9.6 (1.3.0/1.4.1) win(x86-release)
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 18mn
Bit rate mode : Variable
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Language : English
Default : No
Forced : No
Audio
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Duration : 2h 18mn
Bit rate : Unknown / 1 509 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Title : Surround 5.1
Language : English
Default : Yes
Forced : No
Text #1
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : The same subtitle format used on BDs/HD-DVDs
Language : English
Default : No
Forced : No
Text #2
Format : PGS
Language : English
Default : No
Forced : No
Text #3
Format : PGS
Language : English
Default : No
Forced : Yes
Menu
00:00:00.000 : en:Chapter 01
00:09:30.570 : en:Chapter 02
00:17:32.718 : en:Chapter 03
00:25:41.122 : en:Chapter 04
00:32:22.190 : en:Chapter 05
00:43:36.530 : en:Chapter 06
00:51:52.526 : en:Chapter 07
01:01:11.542 : en:Chapter 08
01:10:47.534 : en:Chapter 09
01:17:13.920 : en:Chapter 10
01:26:21.467 : en:Chapter 11
01:37:39.436 : en:Chapter 12
01:47:41.079 : en:Chapter 13
01:58:02.158 : en:Chapter 14
02:03:03.084 : en:Chapter 15
02:07:28.057 : en:Chapter 16
I have experienced the issue where streaming sources do not buffer correctly. Is it possible to make the player pause and indicate it is buffering rather than have the video stutter without any notification of what is going on?
The lack of a buffer pause and message seems more like a problem with DSPlayer than LAV Filters.
(2015-10-20, 16:51)gotham_x Wrote: [ -> ]To install the filter Lentoid HEVC / H.265 decoder, which version is recommended for DSPlayer - Double click on reg.bat and / or reg64.bat, my system is 64Bit
Go with the 32-bit version because Kodi is a 32-bit application.
(2015-10-20, 15:16)oldpoem Wrote: [ -> ] (2015-10-20, 15:05)ashlar Wrote: [ -> ]No, I haven't. If it doesn't work it should be notified to devs, as there's no reason for it not working if older codecs do work.
the rule should be defined in this way
<mediasconfig>
<rules>
<rule filetypes="mkv">
<source filter="lavsource_internal" />
<splitter filter="lavsplitter_internal" />
<video>
<video videocodec="hevc" filter="lentoid_hevc_decoder" />
<video filter="lavvideo_internal" />
</video>
<audio filter="lavaudio_internal" />
<subs filter="xysubfilter_internal" />
</rule>
</rules>
</mediasconfig>
at moment there is not a way to set this rule by Kodi GUI, i will add with next build the "videocodec" parameter also for <rule> and it will be possible to set also by the GUI
the important thing it's always that the rule with more parameters and so restrictions should be placed at first place because it's always selected the rule with the first match
so to be more clear in this way it il will be always loaded lavvideo_internal instead of lenoid...
<video>
</video>
and it will be the same with new <rule> videocodec parameters
(2015-10-20, 21:28)steelman1991 Wrote: [ -> ]Anyone else experiencing issues with the rendering of 'forced' subtitles. Successful display seems particularly random. I have several files which work correctly and others which don't - there is no pattern to it at all. I am presently using 'internal filters' and have attached a log from a file that I know has a 'forced' subtitle header, but which point blank refuses to render. This is a fairly recent addition, so I'm not sure if the others in my collection are working because they have been played previously with a working version - sure I read somewhere that playback states were retained.
i made some quickly test with forced subtitles and seems works for me, maybe can you provide a sample of one of this problematics file
aracnoz - thanks for the response. Will provide a short sample, but will probably be tomorrow now.
(2015-10-20, 23:56)aracnoz Wrote: [ -> ]the rule should be defined in this way
<mediasconfig>
<rules>
<video>
</video>
</rule>
</rules>
</mediasconfig>
Tried it and it still load LAVFlters. Log file as follow. Tried it with hevc,HEVC string , same result.
05:17:42 T:16632 NOTICE: CDSPlayer::OpenFile - DSPlayer: Opening: D:\TearsOfSteel_720p-h265.mkv
05:17:42 T:16632 NOTICE: CDSPlayer::OpenFileInternal - DSPlayer: Opening: D:\TearsOfSteel_720p-h265.mkv
05:17:42 T:14408 NOTICE: Thread CDSPlayer thread start, auto delete: false
05:17:42 T:14408 NOTICE: CDSPlayer::Process - Creating DS Graph
05:17:42 T:9160 NOTICE: Thread CDSGraphThread thread start, auto delete: false
05:17:42 T:9160 NOTICE: Loading filter core factory settings from special://profile/dsplayer/filtersconfig.xml (filters configuration).
05:17:42 T:9160 NOTICE: Loading filter core factory settings from special://xbmc/system/players/dsplayer/filtersconfig.xml (filters configuration).
05:17:42 T:9160 NOTICE: Loading filter core factory settings from special://profile/dsplayer/mediasconfig.xml (medias configuration).
05:17:42 T:9160 NOTICE: Loading filter core factory settings from special://xbmc/system/players/dsplayer/mediasconfig.xml (medias configuration).
05:17:42 T:9160 NOTICE: Successfully loaded rules
05:17:42 T:9160 NOTICE: CFGLoader::InsertAudioRenderer Successfully added "" - DiplayName: to the graph
05:17:42 T:9160 NOTICE: CFGLoader::InsertFilter Successfully added "LAV Splitter Source" to the graph
05:17:59 T:17488 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
05:17:59 T:9160 NOTICE: CFGLoader::InsertSourceFilter Successfully loaded file in the splitter/source
05:17:59 T:9160 NOTICE: CFGLoader::InsertFilter Successfully added "XyVSFilter Auto" to the graph
05:17:59 T:9160 NOTICE: CStreamsManager::LoadIAMStreamSelectStreamsInternal Audio stream found : A: aac lc, 48000 Hz, 5.1 [default] - index: 1
05:17:59 T:9160 NOTICE: CSubtitleManager::Initialize disabled libsubs.dll
05:17:59 T:9160 WARNING: CFGLoader::LoadFilterRules DVDPlayer failed to fetch streams details. Using DirectShow ones
05:17:59 T:9160 NOTICE: CFGLoader::InsertFilter Successfully added "FFDShow Audio Processor" to the graph
05:17:59 T:9160 NOTICE: CFGLoader::InsertFilter Successfully added "LAV Video Decoder" to the graph
05:17:59 T:9160 NOTICE: CFGLoader::InsertFilter Successfully added "LAV Audio Decoder" to the graph
05:18:00 T:9160 NOTICE: Display resolution for madVR ADJUST : 1920x1080@ 24.00 - Full Screen (96) (weight: 0.000)
05:18:01 T:14408 NOTICE: CDSPlayer::Process - Successfully creating DS Graph
05:18:01 T:16416 NOTICE: Thread CGraphManagementThread thread start, auto delete: false
This is when using filename rule
05:33:16 T:14360 NOTICE: CDSPlayer::OpenFile - DSPlayer: Opening: D:\TearsOfSteel_720p-h265.mkv
05:33:16 T:14360 NOTICE: CDSPlayer::OpenFileInternal - DSPlayer: Opening: D:\TearsOfSteel_720p-h265.mkv
05:33:16 T:2892 NOTICE: Thread CDSPlayer thread start, auto delete: false
05:33:16 T:2892 NOTICE: CDSPlayer::Process - Creating DS Graph
05:33:16 T:17516 NOTICE: Thread CDSGraphThread thread start, auto delete: false
05:33:16 T:17516 NOTICE: Loading filter core factory settings from special://profile/dsplayer/filtersconfig.xml (filters configuration).
05:33:16 T:17516 NOTICE: Loading filter core factory settings from special://xbmc/system/players/dsplayer/filtersconfig.xml (filters configuration).
05:33:16 T:17516 NOTICE: Loading filter core factory settings from special://profile/dsplayer/mediasconfig.xml (medias configuration).
05:33:16 T:17516 NOTICE: Loading filter core factory settings from special://xbmc/system/players/dsplayer/mediasconfig.xml (medias configuration).
05:33:16 T:17516 NOTICE: Successfully loaded rules
05:33:16 T:17516 NOTICE: CFGLoader::InsertAudioRenderer Successfully added "" - DiplayName: to the graph
05:33:16 T:17516 NOTICE: CFGLoader::InsertFilter Successfully added "LAV Splitter Source" to the graph
05:33:16 T:7588 NOTICE: metahandler: No SQLite rows requiring update
05:33:16 T:17516 NOTICE: CFGLoader::InsertSourceFilter Successfully loaded file in the splitter/source
05:33:17 T:17516 NOTICE: CFGLoader::InsertFilter Successfully added "XyVSFilter Auto" to the graph
05:33:17 T:17516 NOTICE: CStreamsManager::LoadIAMStreamSelectStreamsInternal Audio stream found : A: aac lc, 48000 Hz, 5.1 [default] - index: 1
05:33:17 T:17516 NOTICE: CSubtitleManager::Initialize disabled libsubs.dll
05:33:17 T:17516 NOTICE: CFGLoader::InsertFilter Successfully added "FFDShow Audio Processor" to the graph
05:33:17 T:17516 NOTICE: CFGLoader::InsertFilter Successfully added "Lentoid HEVC Decoder" to the graph
05:33:17 T:17516 NOTICE: CFGLoader::InsertFilter Successfully added "LAV Audio Decoder" to the graph
05:33:17 T:7588 NOTICE: metahandler: No SQLite rows requiring update
05:33:17 T:17516 NOTICE: Display resolution for madVR ADJUST : 1920x1080@ 24.00 - Full Screen (96) (weight: 0.000)
05:33:18 T:2892 NOTICE: Previous line repeats 8 times.
05:33:18 T:2892 NOTICE: CDSPlayer::Process - Successfully creating DS Graph
05:33:18 T:8384 NOTICE: Thread CGraphManagementThread thread start, auto delete: false
oldpoem
mmm it's very strange
are you sure that's the first defined rule in your mediaconfig, can you also try to set only the rule posted by me just for test
