(2015-11-17, 18:52)huhn Wrote: [ -> ]is "only deinterlace pixel in the middle of the frame" the setting from processing -> deinterlacing "only look at pixels in the center (good for broadcasts, bad for anime)"
http://i1357.photobucket.com/albums/q760...jjtyew.png
if yes it should be renamed it does something different for IVTC. deinterlacing is not effected by it. only deinterlacing the middle of a screen is totally pointless ^^.
That's madVR wording, not anything DSPlayer done.
(2015-11-17, 14:58)aracnoz Wrote: [ -> ] (2015-11-17, 09:41)gotham_x Wrote: [ -> ]@aracnoz
I am using internal filters, with settings Load from madVR active profile, by further testing, I noticed that, if the movie plays in the window, the video plays correctly, if the movie is played in full screen, the movie is played NOT and you have black screen.
I try to provide debug log
http://xbmclogs.com/ptwdp4res/2osvtu/raw
(2015-11-17, 10:35)gotham_x Wrote: [ -> ]I provide screenshots, Film reproduced in full screen, on the right you can see a part of a black screen and a small part of that interface is back after launching the movie in full screen.
you should configure your advancedsettings.xml as described here http://kodi.wiki/view/Log_file/Advanced#...ttings.xml to have a full debug log
anyway i think that your problem could be related to something wrong in your guisettings.xml after the upgrade because
DSPlayer set his window to work on the main screen but then kodi try to change the resolution on the secondary screen
08:36:13 T:6568 NOTICE: Display resolution for madVR ADJUST : 1680x1050@ 59.94 - Full Screen (57) (weight: 0.000) DSPLAYER
08:36:14 T:5624 NOTICE: CDSPlayer:rocess - Successfully creating DS Graph
08:36:14 T:1140 NOTICE: CChaptersManager::LoadChapters Chapter "00:00:00.000" found. Start time: 0
08:36:14 T:1140 NOTICE: CChaptersManager::LoadChapters Chapter "00:02:42.662" found. Start time: 162662
08:36:14 T:1140 NOTICE: CChaptersManager::LoadChapters Chapter "00:10:09.108" found. Start time: 609108
08:36:14 T:1140 NOTICE: CChaptersManager::LoadChapters Chapter "00:17:47.316" found. Start time: 1067316
08:36:14 T:1140 NOTICE: CChaptersManager::LoadChapters Chapter "00:24:33.180" found. Start time: 1473180
08:36:14 T:1140 NOTICE: CChaptersManager::LoadChapters Chapter "00:30:12.477" found. Start time: 1812477
08:36:14 T:1140 NOTICE: CChaptersManager::LoadChapters Chapter "00:35:34.090" found. Start time: 2134090
08:36:14 T:1140 NOTICE: CChaptersManager::LoadChapters Chapter "00:40:47.070" found. Start time: 2447070
08:36:14 T:4528 NOTICE: Display resolution ADJUST : 1920x1080@ 59.94 #2 - Full Screen (17) (weight: 0.000) KODI
so you have to do some tests, pls try to rename your kodi folder in appdata "%appdata%/kodi" just to let Kodi 16.0 to create a new clean folder without any previous configuration, then you have to set your monitor with the option in
System - Video Output - Display mode
if everything properly work, then you can continue step by step to reintergrate your old configuration, so adjust refresh, a different skin etc etc
otherwise you should also try with a single monitor
it could be also possible to fix the problem only by renaming your guisettings.xml in the current installation to generate a new one, but just to be more sure do your test with a clean folder
Hi Aracnoz
I think I understand what the problem is, I did a clean install new Jarvis DSPlayer 16.0 Beta1, and configuration GUI Kodi step by step. in the sense that at each step of the configuration just checking playing a movie with full screen.
This skin with default Confluence and MADNOX, movie playback is successful up when I reach the menu, VIDEO SETTINGS << >> PLAY:
To the card, RULE UPDATE FREQUENCY DISPLAY if you set with ALWAYS and / or AT START / STOP Kodi DSPlayer crashes with black screen, leaving RULE UPDATE FREQUENCY DISPLAY OFF
movie playback is performed correctly with DSPlayer, now I have no idea if this is good or not, this is' ...
(2015-11-17, 20:34)spencerjford Wrote: [ -> ] (2015-11-17, 18:52)huhn Wrote: [ -> ]is "only deinterlace pixel in the middle of the frame" the setting from processing -> deinterlacing "only look at pixels in the center (good for broadcasts, bad for anime)"
there is no word in madVR that only the middle of the picture is deinterlaced and that's not happening.
(2015-11-17, 22:23)huhn Wrote: [ -> ] (2015-11-17, 20:34)spencerjford Wrote: [ -> ] (2015-11-17, 18:52)huhn Wrote: [ -> ]is "only deinterlace pixel in the middle of the frame" the setting from processing -> deinterlacing "only look at pixels in the center (good for broadcasts, bad for anime)"
It tiok from MadVR control panel wording in deinterlace settings.
(2015-11-17, 22:26)oldpoem Wrote: [ -> ]It tiok from MadVR control panel wording in deinterlace settings.
this option isn't even used for normal deinterlacing it's used for IVTC and it is not only deinterlacing the pixel in the middle of the screen.
I don't think
Event Logging is working under System -> Logging. This may be a DSPlayer issue as this feature was not designed to work with DSPlayer.
FYI, the only really interesting feature in Jarvis is the new long-press for remote buttons:
Long-press – Jarvis v16 introduced a long-press for select keystrokes. Holding a key for a couple of seconds enables a secondary command. Currently, this is limited to two keystrokes and only appears to be compatible with eHome receivers:
- Short: Enter – Long: Contextual Menu
- Short: Backspace – Long: Home Screen or Shutdown Menu
This is for those who are unaware of this feature.
(2015-11-17, 23:41)Warner306 Wrote: [ -> ]FYI, the only really interesting feature in Jarvis is the new long-press for remote buttons:
Nope, non-linear stretching is also something I'm looking forward to
(2015-11-17, 21:06)gotham_x Wrote: [ -> ] (2015-11-17, 14:58)aracnoz Wrote: [ -> ] (2015-11-17, 09:41)gotham_x Wrote: [ -> ]@aracnoz
Hi Aracnoz
The safest way to do refresh switching is through Kodi (Video -> Playback -> Adjust display refresh rate). Your video card and madVR should have these features disabled if they are available.
I took CinemaVision for a test drive and it failed at one part of the sequence. iTunes trailers would not play and were skipped. Playing trailers based on "Content" in your collection and a "File" work fine.
My settings for trailers look like this:
Complete Log
The same sequence works when played with DVDPlayer.
(2015-11-17, 22:54)huhn Wrote: [ -> ] (2015-11-17, 22:26)oldpoem Wrote: [ -> ]It tiok from MadVR control panel wording in deinterlace settings.
That should be discussed in MadVR thread at doom9 forum. Aracnoz just create settings gui to be easily selectable in Kodi. It took wording from madvr dialog not created new one.
the wording in madVR is correct the wording in kodi is wrong why should i go in the madVR thread for this?
Warner306
In fact, I agree that the switching frequency should be set by the GUI Kodi, it appears that in the previous version Kodi DSPlayer (Video -> Playback -> Adjust display refresh rate) was a setting to 'START / STOP and everything worked perfectly.
In madVR where you have to look if these features are disabled?
(2015-11-18, 00:35)huhn Wrote: [ -> ]the wording in madVR is correct the wording in kodi is wrong why should i go in the madVR thread for this?
OK. I looked it up and you're right. It's typo.
(2015-11-18, 00:35)gotham_x Wrote: [ -> ]@Warner306
Either kodi and madvr has their own refresh rate switching procedure. The settings in Kodi GUI control Kodi's own not madvr. In general you want only one enabled not both. So if you enable it through Kodi GUI you are advised to disable madvr anyway.
If you want to use madvr one, you have to manually enable in madvr control panel and disable Kodi's through GUI.
But from my past experience I have better result with Kodi enabled and madvr disabled.
