(2016-01-05, 20:42)Wanilton Wrote: [ -> ]Kodi Jarvis beta 5 + dsplayer with all update until now (01/05/2016).
link for download:
https://dl.dropboxusercontent.com/u/7799...11.exe.exe
Warnings:
- This is an unofficial Kodi build not from Team Kodi.
- This build comes with no warranties, explicit or implied, and you use it at your own risk.
- This build was compiled by Wanilton, for use only in Windows OS, and have same functions official Kodi Jarvis build Nightlie + dsplayer support.
git:
https://github.com/mediaBrasil/xbmc/tree...r_dsplayer
PS: I will no update or developer dsplayer, only'll keep the current code by aracnoz update with Jarvis 16.
Happy new year!!!
Thanks as usual Wanilton!
Just noticed that the file is a "double exe" like exe.exe...
Just to spot it, no issues in the installation of course!
Here I Am again...
Just one question for clarification: I have noticed that in the official beta4 release, during the installation process is possible to check/uncheck the installation of some Audio DSP Addons; this is not the case for the beta5 with DSPlayer. Is this option also been removed from the official beta5 (that btw is not available for download)?
Thanks in advance for your help!
(2016-01-06, 01:58)axlt2002 Wrote: [ -> ]Here I Am again...
This is probably a deficit of the installer created by Wanilton. You can still install these addons manually from the repo, but I bet they don't work with DSPlayer anyways.
(2016-01-05, 23:09)djoole Wrote: [ -> ]Hi,
I've noticed a problem that I didn't have before, but can't exactly tell since when i have this problem (upgrading to Jarvis? Changing from MQ5 to MQ6? A new DSPlayer build?)
Here it is : I can't seek DVD iso videos. With left/right/up/down, i can't seek anymore in the video.
And when I launch a DVD iso that was partially played, and choose to start where I left it, it starts from the beginning.
In other words, if I stop a DVD playback before the end, I'm condemned to watch it again from the beginning.
Am I the only one having this problem?
Nothing suspect in logs; here is an example of a big seek :
21:58:50 T:2396 DEBUG: Keyboard: scancode: 0x48, sym: 0x0111, unicode: 0x0000, modifier: 0x0
21:58:50 T:2396 DEBUG: CInputManager::OnKey: up (0xf080) pressed, action is ChapterOrBigStepForward
21:58:50 T:2396 DEBUG: CDSPlayer::PostMessageA Message posted : 5 on thread 0x528
21:58:50 T:1320 DEBUG: CDSPlayer::HandleMessages Message received : 5 on thread 0x528
21:58:50 T:1320 DEBUG: CAnnouncementManager - Announcement: OnSeek from xbmc
21:58:50 T:1320 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnSeek
21:58:51 T:2396 DEBUG: ------ Window Init (DialogSeekBar.xml) ------
21:58:51 T:3500 DEBUG: PERIPHERALS::CPeripherals::GetMappingForDevice - device (2548:1002) mapped to Pulse-Eight CEC Adapter (type = cec)
21:58:53 T:2396 DEBUG: ------ Window Deinit (DialogSeekBar.xml) ------
No one here having a DVD ISO that could confim this issue?
(2016-01-06, 02:57)Warner306 Wrote: [ -> ] (2016-01-06, 01:58)axlt2002 Wrote: [ -> ]Here I Am again...
Thanks Warner306 for your answer. I didn't find such Addons on the repository...I will check better.
If anyway Wanilton can include them again, it would be useful.
Have a nice day you all!
Kodi Jarvis beta 5 + dsplayer with all update until now (01/06/2016).
link for download:
https://dl.dropboxusercontent.com/u/7799...0.dx11.exe
Warnings:
git:
Included Audio DSP addons missing in previous versions.
Thanks for your usual and prompt effort Wanilton!
I am running this on an old system Win7, (Athlon 3500+), ATi AMD 6450 GPU, Emby for Kodi with Emby as my media server.
I could have sworn a week or so ago everything worked beautifully, but NOW I cannot get DSPlayer/madvr into "full screen exclusive" mode and I am trying with settings for the last few days but no go.
I have no problem with MPC-HC and the same madvr settings, there it immediately goes into D3D9 fullscreen exclusive mode. But not DSPlayer from within Kodi.
The issue is, only with fullscreen exclusive mode I get a smooth, stutter-free experience.
Someone mentioned it's impossible to activate D3D fullscreen esclusive when another app has the focus, but I would not know what other app that would be. There is nothing else running on this PC. Looking at my settings in Kodi/DSPlayer I set everything so that it SHOULD use exclusive mode and not windowed. But CTRL-J alwys tells me its using windowed/old path.
Cheers,
G
Edit: Also, when starting Kodi from the Icon, about 40% of the time it crashes on startup. (white screen, hang). Then I try again and it works. I have a feeling this is related.
EDIT: *** SOLVED ***
It was indeed the Video calibration preventing Kodi/DSplayer from going into Fullscreen exclusive, for that particular resolution. I set it back to default values and now it works.
Thanks for your awesome work.
My kodi isn't smooth and my hardware its not weak, whats the problem?
Also with madvr +lavfilters my player is lagging A LOT (R9 270x crossfire).
Is there any solution?
(2016-01-07, 19:19)pwner Wrote: [ -> ]Thanks for your awesome work.
It is impossible to tell with that information. Can you take a picture of your rendering stats (Cntrl + J) and post them here?
Thanks for supplying updates for KODI/DSPLAYER, I could never get it to work before, I have one small problem though, I can't change brightness during film playback, am I missing something or is this normal.
(2016-01-08, 00:23)Picard Wrote: [ -> ]Thanks for supplying updates for KODI/DSPLAYER, I could never get it to work before, I have one small problem though, I can't change brightness during film playback, am I missing something or is this normal.
These settings only apply to DVDPlayer. If you think your levels are off, I would turn on or turn off calibration controls in madVR under "devices."
It is best to adjust picture controls before playback on the display. madVR will try and preserve these levels during playback. Or, if you have access to a colorimeter, create a 3D LUT file, which madVR can load to enforce a correct gamut.
(2016-01-06, 11:17)djoole Wrote: [ -> ] (2016-01-05, 23:09)djoole Wrote: [ -> ]Hi,
Really?
No one?
Doesn't have to be a ISO file, actually, my DVD rips are in folder VIDEO_TS mode.
Many thanks to Wanilton to provide us with recent builds of Kodi/DSPlayer ...
Good evening
Why in the reproduction, the subtitle position does not match the real frame?
Playing MKV files (Bluray lossless) with subtitles PGS with KODI, the position is shifted toward the bottom and not in the center of the video where they are placed originally.
I have to correct some settings?
Thank you
KODI DSPlayer
MPCHC & other players
