(2016-06-06, 16:54)bollstedt Wrote: [ -> ]I found a good source for sample profiles for different graphic cards (at the end of 1st post): http://emby.media/community/index.php?/t...-hd-audio/
Might be handy if you want to squeeze out the best quality of one's setup.
I've seen that link. Good information for Emby users, but most of that information is already covered in the Kodi forums. Maybe the chart is useful, but it is definitely untested.
Is it better to use LAVVideo HEVC option unticked or ticked? for playback of x265/hevc.
I have an i7 4970 and a 980ti.
Has anybody been successful getting DSPlayer 16.1, Lav .68, MadVR 90.4, to work with PVR_WMC addon? My 1080p mkv movies are working fine in DSPlayer with madvr and lav, but live tv and recording don't. I have been successfully using mpchc with madvr for over a year; so my settings should be correct (This includes Live TV streams and recordings). The end goal is to use madvr with guide for live TV in DSPlayer via serverWMC. I keep getting the same error in my log files; which are below in bold.
11:13:55 T:2908 NOTICE: CDSPlayer:
rocess - Creating DS Graph
11:13:55 T:12972 NOTICE: Loading filter core factory settings from special://profile/dsplayer/filtersconfig.xml (filters configuration).
11:13:55 T:12972 NOTICE: Loading filter core factory settings from special://xbmc/system/players/dsplayer/filtersconfig.xml (filters configuration).
11:13:55 T:12972 NOTICE: Loading filter core factory settings from special://masterprofile/dsplayer/mediasconfig.xml (medias configuration).
11:13:55 T:12972 NOTICE: special://masterprofile/dsplayer/mediasconfig.xml does not exist. Skipping.
11:13:55 T:12972 NOTICE: Loading filter core factory settings from special://xbmc/system/players/dsplayer/mediasconfig.xml (medias configuration).
11:13:55 T:12972 NOTICE: Successfully loaded rules
11:13:55 T:12972 ERROR: CFGLoader::LoadFilterRules Extension "" not found. Please check mediasconfig.xml
11:13:55 T:12972 ERROR: CFGManager::RenderFileXbmc Failed to load filters rules
11:13:55 T:12972 NOTICE: thread end: CDSGraphThread::OnExit()
11:13:55 T:2908 ERROR: CDSPlayer:rocess - Failed creating DS Graph
I'm a first time poster, and a newer Kodi user. I'm hoping I'm just missing something simple here.
Can anybody point me in the right direction? Thanks in advance!
(2016-06-07, 15:16)master345 Wrote: [ -> ]Is it better to use LAVVideo HEVC option unticked or ticked? for playback of x265/hevc.
The 980 Ti doesn't support HEVC decoding.
(2016-06-07, 18:28)elusivefuzz Wrote: [ -> ]Has anybody been successful getting DSPlayer 16.1, Lav .68, MadVR 90.4, to work with PVR_WMC addon? My 1080p mkv movies are working fine in DSPlayer with madvr and lav, but live tv and recording don't. I have been successfully using mpchc with madvr for over a year; so my settings should be correct (This includes Live TV streams and recordings). The end goal is to use madvr with guide for live TV in DSPlayer via serverWMC. I keep getting the same error in my log files; which are below in bold.
11:13:55 T:2908 NOTICE: CDSPlayer:rocess - Creating DS Graph
The following PVR backends are officially supported:
MediaPortal and Argus TV – Live TV Users
Built-in support is available for live TV streams using the
rtsp protocol. This service has been tested with
MediaPortal and
Argus TV PVR backends. Instructions and required add-on settings are found here:
MediaPortal and ArgusTV PVR.
NextPVR – Live TV Users
Support for
NextPVR using the
http protocol is also possible. Instructions for NextPVR are found here:
NextPVR Directshow Filter for DSPlayer.
(2016-06-07, 18:56)Warner306 Wrote: [ -> ] (2016-06-07, 15:16)master345 Wrote: [ -> ]Is it better to use LAVVideo HEVC option unticked or ticked? for playback of x265/hevc.
this is not correct it supports hybrid decoding for 8 bit HEVC.
but i highly advice against it.
it eats the GPU which is very bad for madVR usages.
it is usually not really faster than software decoding too.
(2016-06-07, 18:58)Warner306 Wrote: [ -> ]The following PVR backends are officially supported:
Built-in support is available for live TV streams using the rtsp protocol. This service has been tested with MediaPortal and Argus TV PVR backends. Instructions and required add-on settings are found here: MediaPortal and ArgusTV PVR.
Support for NextPVR using the http protocol is also possible. Instructions for NextPVR are found here: NextPVR Directshow Filter for DSPlayer.
Thanks Warner,
I'll tinker with these backends, and see if I can get this up and running. I appreciate the help; your wisdom is prevalent all over this thread.
will this work with Reclock?
(2016-06-10, 02:11)robl45 Wrote: [ -> ]will this work with Reclock?
Yes, check the set up guide in my signature.
(2016-06-10, 02:12)Warner306 Wrote: [ -> ] (2016-06-10, 02:11)robl45 Wrote: [ -> ]will this work with Reclock?
I seem to have tried this a long time back like years back and it didn't work. I just found your setup guide after posting. But it also seems to say this isn't being developed anymore?
(2016-06-10, 02:17)robl45 Wrote: [ -> ] (2016-06-10, 02:12)Warner306 Wrote: [ -> ] (2016-06-10, 02:11)robl45 Wrote: [ -> ]will this work with Reclock?
DSPlayer supports Jarvis 16.1 final. So, as long as you don't mind Jarvis, it works just fine. It still supports the most recent versions of madVR.
I use it almost everyday to watch something (add-on or otherwise). You can't beat the support for madVR. madVR is updated at least once a month with new features. However, madVR is most useful when paired with a gaming graphics card because it is like a video game to the driver and uses a lot of graphics horsepower.
I already use this same configuration with MPC-HC as an external player. Wanted to just get back to using one program, but that doesn't make much sense if it won't be supported in the future
(2016-06-10, 05:13)Warner306 Wrote: [ -> ] (2016-06-10, 02:17)robl45 Wrote: [ -> ] (2016-06-10, 02:12)Warner306 Wrote: [ -> ]Yes, check the set up guide in my signature.
(2016-06-10, 15:24)robl45 Wrote: [ -> ]I already use this same configuration with MPC-HC as an external player. Wanted to just get back to using one program, but that doesn't make much sense if it won't be supported in the future
(2016-06-10, 05:13)Warner306 Wrote: [ -> ] (2016-06-10, 02:17)robl45 Wrote: [ -> ]I seem to have tried this a long time back like years back and it didn't work. I just found your setup guide after posting. But it also seems to say this isn't being developed anymore?
Might as well give it a try. You won't lose any data. Also, you could install DSPlayer as a portable installation and have two Kodi installations.
(2016-05-17, 03:00)Warner306 Wrote: [ -> ]You can install DSPlayer as a portable installation.
Instructions:- Install to a drive with write permission.
- You don't need any Start Menu shortcuts.
- Make sure you don't uninstall your previous Kodi installation when prompted to uninstall other versions.
Kodi Portable Mode
Instructions for portable installation above.
