2015-04-03, 01:48
READ THIS FIRST
This a rough work in progress to update VEVO and VEVO TV. I decided to write an entirely new version for the most recent API. There are many major issues with this still:
- Only resolution right now is 1080 or whatever is the highest available.
- Some work needs to be done to pre-fetch the images, it's quite slow.
- Need to add Shows, Tours, Playlists, etc.
- Need to add next page
- International Support
- Facebook login
I'm putting this out there because I will need help testing the translations that are internal to VEVO and it will help if I can have folks in different locations tell me if this works or not and to check if the native language support is working. I anticipate all kinds of problems because it looks like the international versions have different metadata structures, but I will slowly work to resolve the issues. Please be patient.
This is a first very rough cut which is English only to test basic functionality. The next version will make use of the translation tables and will have many more configuration options. This initial version needs a reasonably fast (4 Mbps+) internet connection to work without excessive buffering, this will be reduced in the next version.
This addon can co-exist with the current VEVO addon. You will know the difference by seeing VEVO TV on the main menu for V2.x.x.
Version 2.0.2 in my git:
https://github.com/learningit/plugin.video.myvevo/
- Facebook login
