2015-04-04, 16:31
Hello
For the past few days, i've been trying to get vdr working with kodi on my raspberry pi 2. I installed vdr, vnsi and iptv plugins using this guide
http://forum.kodi.tv/showthread.php?tid=189534.
when i try to run vdr, this happens
I am guessing this is because there are no dvb cards installed. but since i want to use iptv, i won't be installing them anyway, so how could i get vdr to run?
Also, how should i specify an iptv channel in channels.conf. According to the vdr-iptv page,
But it does not say what the last 9 values are.
I want to stream an http stream, for instance http://192.168.1.2:4022/rtp/226.11.3.77:6000
(this http stream is created by udpxy)
Here is the information about the stream(it is a TS stream) (taken from mpc-hc)
Any help/suggestions/advice are greatly appreaciated
root@Bash-Rpi:~# vdr -V
vdr (2.2.0/2.2.0) - The Video Disk Recorder
vnsiserver (1.3.0) - VDR-Network-Streaming-Interface (VNSI) Server
iptv (2.2.0) - Experience the IPTV
streamdev-server (0.6.1-git) - VDR Streaming Server
streamdev-client (0.6.1-git) - VTP Streaming Client
root@Bash-Rpi:~# runvdr
vdr: no primary device found - using first device!
TV1;IPTV:10:S=1|P=0|F=UDP|U=127.0.0.1|A=1234:I:0:512:650:2321:0:1:0:0:0
| | | | | | Source type ("I")
| | | | | Stream parameter
| | | | | UDP: multicast port
| | | | | CURL: <>
| | | | | HTTP: HTTP port number
| | | | | FILE: file delay (ms)
| | | | | EXT: script parameter
| | | | Stream address
| | | | UDP: multicast [source@]group address
| | | | CURL: HTTP/HTTPS URL; colons (%3A) and pipes (%7C) shall be URL encoded
| | | | HTTP: URL; missing the scheme name part and possible port declaration
| | | | FILE: file location
| | | | EXT: script location
| | | Stream protocol ("UDP", "CURL", "HTTP", "FILE", "EXT")
| | Pid scanner ("0" disable, "1" enable)
| Section id (Sid/Nid/Tid) scanner ("0" disable, "1" enable)
Unique enumeration
Video: MPEG4 Video (H264) 720x576 (15:11) 25fps [V: h264 main L3.0, yuv420p, 720x576]
Audio: MPEG Audio 48000Hz stereo 128kbps [A: mp2, 48000 Hz, stereo, 128 kb/s]
