Full Version: Can You Easily Change The Weather Units From Fahrenheit To Centigrade?
I have just set up the Weather addon. I have set up Yahoo, Openweathermap and the Met Office but all three are in Fahrenheit and I want Centigrade.
I have looked at the settings but I can't seem to find where I can change the units.
Does anyone know?
(I am using Kodi v14 on my Minix x8-H and I'm in the UK)
I think its OK as I've just seen a post from earlier that says to change the settings in the Appearance to my region.
I will give that a go
It will be more easy in V.15 ...
Yeah, it's right about where you select MPH or kmph
