Hallo,
are there any plans to make the re-touched skin compatible with Kodi 14 Helix? What would it take to make it compatible?
Kind regards
Max
we're not osmc. i'm sure they have their own support forum.
This has ABSOLUTELY NOTHING todo with OSMC. I am running Kodi 14 on Arch Linux, Geexbox and Windows. Nowhere can I install your re-touched skin. It is, however included in the iPad and iPhone versions, as mentioned in the linked thread. As I only need it on my two OSMC devices, which are controlled by touchscreen, I mentioned OSMC here.
Well, thanks to your extreme unwillingness to be helpful to potential users (same as for this poor guy, who didn't even receive an unhelpful answer:
http://forum.kodi.tv/showthread.php?tid=222685 ), I have lost any interest in using your skin. Confluence works just fine once you get used to it.
Max
so now we're to blame for the fact that osmc ships with a crippled version of kodi?
think again.
Is there any reason to not have retouched also in the add-on repo? I always assumed it was to prevent some kind of conflict. It would be nice to download it straight from the repo for various Linux devices that have touch screens
I second this - I use re-touched on the o2 Joggler, and it would be more convenient to get updates via the addon-manager. Also the latest ready to go download for Helix on github seems older than the latest code for the Helix version - would be useful to have an up to date build. Thanks.
I just did a clean install of 14.2 on a Surface Pro, and re-touched is marked as incompatible in the add-ons. Is this a re-touched problem or a kodi problem? Confluence is unusable on a surface pro so this is a real PITA.
edit: downloading the zip file from github in the link above it works fine, the one included in the repositories must be an old version.
