2015-04-13, 19:26
Hi all,
This is my first post, so I'd just like to say thank you all in advance. This is a great community.
My question is quite a specific one, and I have searched for it without any luck. Essentially, I want to run xbmc on a hackintosh computer, that will be located upstairs. I want to view xbmc on the TV downstairs. I have an Apple TV 3 which I can use AirPlay (extended display) to run xbmc on. Im pretty sure I can set xbmc to open only on the extended display (I think). My question is, can I control xbmc using an iOS app, while it is being displayed on the Apple TV 3 in extended mode, while still using the Mac for other things on the other monitors? Has anyone tried this? If so, some feedback would be nice. What is the quality like using this extended display mode when running xbmc? Also, is there a way to automate the process of AirPlay through the xbmc remotes available? Or is it much more advisable to run a long hdmi cable?
I have seen Plexconnect which would be ideal if only xbmc had something similar?!
Many thanks,
Will
Many thanks,
Will
