Full Version: South Park Unofficial
Pages: 1 2 3 4 5 6 7 8 9 10 11 12
Understandable....thank you much!
Posted on Reddit about the southpark addon not working since a month or so even with fresh install. I've been told to post the full log here !
12:55:32 T:3668 NOTICE: special://profile/ is mapped to: special://masterprofile/
12:55:32 T:3668 NOTICE: -----------------------------------------------------------------------
12:55:32 T:3668 NOTICE: Starting Kodi (16.1 Git:20160424-c327c53). Platform: Windows NT x86 32-bit
12:55:32 T:3668 NOTICE: Using Release Kodi x32 build
12:55:32 T:3668 NOTICE: Kodi compiled Apr 24 2016 by MSVC 180040629 for Windows NT x86 32-bit version 6.0 (0x06000000)
12:55:32 T:3668 NOTICE: Running on MSI MS-7752 with Windows 7 SP1, kernel: Windows NT x86 64-bit version 6.1
12:55:32 T:3668 NOTICE: Host CPU: Intel® Core™ i5-3470 CPU @ 3.20GHz, 4 cores available
12:55:32 T:3668 NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz
12:55:32 T:3668 NOTICE: Running with administrator rights
12:55:32 T:3668 NOTICE: Aero is enabled
12:55:32 T:3668 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\Kodi
12:55:32 T:3668 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\Kodi
12:55:32 T:3668 NOTICE: special://masterprofile/ is mapped to: C:\Users\Proto\AppData\Roaming\Kodi\userdata
12:55:32 T:3668 NOTICE: special://home/ is mapped to: C:\Users\Proto\AppData\Roaming\Kodi\
12:55:32 T:3668 NOTICE: special://temp/ is mapped to: C:\Users\Proto\AppData\Roaming\Kodi\cache
12:55:32 T:3668 NOTICE: The executable running is: C:\Program Files (x86)\Kodi\Kodi.exe
12:55:32 T:3668 NOTICE: Local hostname: Proto-PC
12:55:32 T:3668 NOTICE: Log File is located: C:\Users\Proto\AppData\Roaming\Kodi\kodi.log
12:55:32 T:3668 NOTICE: load settings...
12:55:32 T:3668 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
12:55:32 T:3668 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
12:55:32 T:3668 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
12:55:32 T:3668 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
12:55:32 T:3668 NOTICE: Default DVD Player: dvdplayer
12:55:32 T:3668 NOTICE: Default Video Player: dvdplayer
12:55:32 T:3668 NOTICE: Default Audio Player: paplayer
12:55:32 T:3668 NOTICE: Disabled debug logging due to GUI setting. Level 0.
12:55:32 T:3668 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
12:55:32 T:3668 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
12:55:32 T:3668 NOTICE: Loaded playercorefactory configuration
12:55:32 T:3668 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
12:55:32 T:3668 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
12:55:32 T:6404 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_DTSHD" on device "NS-24D510NA15-4 (NVIDIA High Definition Audio)" seems to be not supported.
12:55:32 T:6404 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_TRUEHD" on device "NS-24D510NA15-4 (NVIDIA High Definition Audio)" seems to be not supported.
12:55:32 T:6404 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_EAC3" on device "NS-24D510NA15-4 (NVIDIA High Definition Audio)" seems to be not supported.
12:55:32 T:6404 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_DTS" on device "NS-24D510NA15-4 (NVIDIA High Definition Audio)" seems to be not supported.
12:55:32 T:6404 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: sample rate 192khz on device "NS-24D510NA15-4 (NVIDIA High Definition Audio)" seems to be not supported.
12:55:32 T:6404 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_LPCM" on device "NS-24D510NA15-4 (NVIDIA High Definition Audio)" seems to be not supported.
12:55:33 T:6404 NOTICE: Found 2 Lists of Devices
12:55:33 T:6404 NOTICE: Enumerated DIRECTSOUND devices:
12:55:33 T:6404 NOTICE: Device 1
12:55:33 T:6404 NOTICE: m_deviceName : {2310E712-9623-4AF8-B23C-98F1A8B75ABD}
12:55:33 T:6404 NOTICE: m_displayName : SPDIF - Realtek Digital Output (Realtek High Definition Audio)
12:55:33 T:6404 NOTICE: m_displayNameExtra: DIRECTSOUND: Realtek Digital Output (Realtek High Definition Audio)
12:55:33 T:6404 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
12:55:33 T:6404 NOTICE: m_channels : FL,FR
12:55:33 T:6404 NOTICE: m_sampleRates : 48000
12:55:33 T:6404 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_AC3,AE_FMT_DTS
12:55:33 T:6404 NOTICE: Device 2
12:55:33 T:6404 NOTICE: m_deviceName : {815E8417-E060-4C56-A724-473CA3FDCC8E}
12:55:33 T:6404 NOTICE: m_displayName : Speakers - Haut-parleurs (Turtle Beach P11 Headset)
12:55:33 T:6404 NOTICE: m_displayNameExtra: DIRECTSOUND: Haut-parleurs (Turtle Beach P11 Headset)
12:55:33 T:6404 NOTICE: m_deviceType : AE_DEVTYPE_PCM
12:55:33 T:6404 NOTICE: Device 3
12:55:33 T:6404 NOTICE: m_deviceName : {87EF6A6C-64EA-48D6-8CE9-515E3B1FDD28}
12:55:33 T:6404 NOTICE: m_displayName : HDMI - NS-24D510NA15-4 (NVIDIA High Definition Audio)
12:55:33 T:6404 NOTICE: m_displayNameExtra: DIRECTSOUND: NS-24D510NA15-4 (NVIDIA High Definition Audio)
12:55:33 T:6404 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
12:55:33 T:6404 NOTICE: Device 4
12:55:33 T:6404 NOTICE: m_deviceName : {E4C4E742-7853-4192-B23A-AD5EAA27336C}
12:55:33 T:6404 NOTICE: m_displayName : Speakers - Haut-parleurs (Realtek High Definition Audio)
12:55:33 T:6404 NOTICE: m_displayNameExtra: DIRECTSOUND: Haut-parleurs (Realtek High Definition Audio)
12:55:33 T:6404 NOTICE: m_channels : FL,FR,FC,BL,BR,LFE
12:55:33 T:6404 NOTICE: Device 5
12:55:33 T:6404 NOTICE: m_deviceName : default
12:55:33 T:6404 NOTICE: m_displayName : default
12:55:33 T:6404 NOTICE: Enumerated WASAPI devices:
12:55:33 T:6404 NOTICE: m_displayNameExtra: WASAPI: Realtek Digital Output (Realtek High Definition Audio)
12:55:33 T:6404 NOTICE: m_sampleRates : 192000,96000,48000,44100
12:55:33 T:6404 NOTICE: m_dataFormats : AE_FMT_DTS,AE_FMT_AC3,AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
12:55:33 T:6404 NOTICE: m_displayNameExtra: WASAPI: Haut-parleurs (Turtle Beach P11 Headset)
12:55:33 T:6404 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
12:55:33 T:6404 NOTICE: m_displayNameExtra: WASAPI: NS-24D510NA15-4 (NVIDIA High Definition Audio)
12:55:33 T:6404 NOTICE: m_sampleRates : 192000,48000,44100
12:55:33 T:6404 NOTICE: m_dataFormats : AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
12:55:33 T:6404 NOTICE: m_displayNameExtra: WASAPI: Haut-parleurs (Realtek High Definition Audio)
12:55:33 T:6404 NOTICE: m_channels : FL,FR,FC,LFE,SL,SR,BL,BR
12:55:33 T:6404 NOTICE: m_dataFormats : AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
12:55:33 T:3668 NOTICE: Running database version Addons20
12:55:33 T:3668 NOTICE: ADDONS: Using repository repository.xbmc.org
12:55:33 T:3668 NOTICE: Found screen: Moniteur Plug-and-Play générique on NVIDIA GeForce GTX 970, adapter 0.
12:55:33 T:3668 NOTICE: Found screen: Moniteur Plug-and-Play générique on NVIDIA GeForce GTX 970, adapter 1.
12:55:33 T:3668 NOTICE: Primary mode: 1920x1080@ 60.00 - Full Screen
12:55:33 T:3668 NOTICE: Secondary mode: 1920x1080@ 60.00 #2 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 640x480@ 59.94 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 640x480@ 60.00 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 720x480@ 60.00 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 720x480@ 59.94 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 720x576@ 56.00 - Full Screen
12:55:33 T:3668 NOTICE: Previous line repeats 2 times.
12:55:33 T:3668 NOTICE: Additional mode: 720x576@ 60.00 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 720x576@ 75.00 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 800x600@ 56.00 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 800x600@ 60.00 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 800x600@ 75.00 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1024x768@ 60.00 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1024x768@ 70.00 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1024x768@ 75.00 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1152x864@ 60.00 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1176x664@ 60.00 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1176x664@ 59.94 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1280x720@ 60.00 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1280x720@ 59.94 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1280x768@ 60.00 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1280x800@ 60.00 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1280x800@ 75.00 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1280x960@ 60.00 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1280x1024@ 60.00 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1360x768@ 60.00 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1366x768@ 60.00 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1600x900@ 59.94 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1600x900@ 60.00 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1600x1024@ 59.94 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1600x1024@ 60.00 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1680x1050@ 59.94 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1680x1050@ 60.00 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1768x992@ 30.00i - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1768x992@ 29.97i - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1920x1080@ 60.00 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1920x1080@ 30.00i - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1920x1080@ 29.97i - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1920x1080@ 24.00 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1920x1080@ 23.98 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1920x1080@ 25.00 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1920x1080@ 30.00 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1920x1080@ 29.97 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1920x1080@ 59.94 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1440x900@ 60.00 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1920x1080@ 60.00 #2 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 640x480@ 60.00 #2 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 720x480@ 56.00 #2 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 720x480@ 60.00 #2 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 720x576@ 56.00 #2 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 720x576@ 60.00 #2 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 800x600@ 56.00 #2 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 800x600@ 60.00 #2 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1024x768@ 60.00 #2 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1024x768@ 70.00 #2 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1152x864@ 75.00 #2 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1280x720@ 60.00 #2 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1280x768@ 60.00 #2 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1280x800@ 60.00 #2 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1280x960@ 60.00 #2 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1280x960@ 75.00 #2 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1280x1024@ 60.00 #2 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1280x1024@ 75.00 #2 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1360x768@ 60.00 #2 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1366x768@ 60.00 #2 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1600x900@ 60.00 #2 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1600x1024@ 60.00 #2 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1680x1050@ 60.00 #2 - Full Screen
12:55:33 T:3668 NOTICE: Additional mode: 1440x900@ 60.00 #2 - Full Screen
12:55:33 T:3668 NOTICE: Checking resolution 16
12:55:34 T:3668 NOTICE: Running database version Addons20
12:55:34 T:3668 NOTICE: Running database version ViewModes6
12:55:34 T:3668 NOTICE: Running database version Textures13
12:55:34 T:3668 NOTICE: Running database version MyMusic56
12:55:34 T:3668 NOTICE: Running database version MyVideos99
12:55:34 T:3668 NOTICE: Running database version TV29
12:55:34 T:3668 NOTICE: Running database version Epg11
12:55:34 T:3668 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
12:55:34 T:3668 NOTICE: ActiveAE DSP - starting
12:55:34 T:3668 NOTICE: initialize done
12:55:34 T:3668 NOTICE: Running the application...
12:55:34 T:3668 NOTICE: starting upnp client
12:55:34 T:1652 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
12:55:34 T:1652 NOTICE: UDP: Listening on port 9777
12:56:29 T:3668 NOTICE: DVDPlayer: Opening: rtmpe://viacommtvstrmfs.fplive.net:1935/viacommtvstrm
12:56:29 T:3668 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
12:56:29 T:1500 NOTICE: Creating InputStream
12:56:51 T:1500 ERROR: RTMP_Connect0, failed to connect socket. 10060 (Unknown error)
12:56:51 T:1500 ERROR: CDVDPlayer::OpenInputStream - error opening [rtmpe://viacommtvstrmfs.fplive.net:1935/viacommtvstrm]
12:56:51 T:1500 NOTICE: CDVDPlayer::OnExit()
12:56:51 T:3668 ERROR: Playlist Player: skipping unplayable item: 0, path [rtmpe://viacommtvstrmfs.fplive.net:1935/viacommtvstrm]
12:56:53 T:3668 NOTICE: CDVDPlayer::CloseFile()
12:56:53 T:3668 NOTICE: DVDPlayer: waiting for threads to exit
12:56:53 T:3668 NOTICE: DVDPlayer: finished waiting
12:56:54 T:3668 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.southpark_unofficial/?mode=play&thumbnail=http%3a%2f%2f4.images.southparkstudios.com%2fimages%2fshows%2fsouth-park%2fepisode-thumbnails%2fseason-12%2fsouth-park-s12e06-over-logging_16x9.jpg&title=Over%20Logging&url=68dc2618-ecfd-11e0-aca6-0026b9414f30
12:56:54 T:3668 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.southpark_unofficial/?mode=play&thumbnail=http%3a%2f%2f4.images.southparkstudios.com%2fimages%2fshows%2fsouth-park%2fepisode-thumbnails%2fseason-12%2fsouth-park-s12e06-over-logging_16x9.jpg&title=Over%20Logging&url=68dc2618-ecfd-11e0-aca6-0026b9414f30) failed
12:56:58 T:3668 NOTICE: DVDPlayer: Opening: rtmpe://viacommtvstrmfs.fplive.net:1935/viacommtvstrm
12:56:58 T:3668 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
12:56:58 T:5880 NOTICE: Creating InputStream
12:57:19 T:5880 ERROR: RTMP_Connect0, failed to connect socket. 10060 (Unknown error)
12:57:19 T:5880 ERROR: CDVDPlayer::OpenInputStream - error opening [rtmpe://viacommtvstrmfs.fplive.net:1935/viacommtvstrm]
12:57:19 T:5880 NOTICE: CDVDPlayer::OnExit()
12:57:19 T:3668 ERROR: Playlist Player: skipping unplayable item: 0, path [rtmpe://viacommtvstrmfs.fplive.net:1935/viacommtvstrm]
12:57:21 T:3668 NOTICE: CDVDPlayer::CloseFile()
12:57:21 T:3668 NOTICE: DVDPlayer: waiting for threads to exit
12:57:21 T:3668 NOTICE: DVDPlayer: finished waiting
12:57:22 T:3668 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.southpark_unofficial/?mode=play&thumbnail=http%3a%2f%2f1.images.southparkstudios.com%2fimages%2fshows%2fsouth-park%2fepisode-thumbnails%2fseason-18%2fsouth-park-s18e08-cock-magic_16x9.jpg&title=Cock%20Magic&url=4a46198b-0cbb-4ebd-91d1-37480fbae44e
12:57:22 T:3668 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.southpark_unofficial/?mode=play&thumbnail=http%3a%2f%2f1.images.southparkstudios.com%2fimages%2fshows%2fsouth-park%2fepisode-thumbnails%2fseason-18%2fsouth-park-s18e08-cock-magic_16x9.jpg&title=Cock%20Magic&url=4a46198b-0cbb-4ebd-91d1-37480fbae44e) failed
12:57:26 T:3668 NOTICE: DVDPlayer: Opening: rtmpe://viacommtvstrmfs.fplive.net:1935/viacommtvstrm
12:57:26 T:3668 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
12:57:26 T:8144 NOTICE: Creating InputStream
12:57:47 T:8144 ERROR: RTMP_Connect0, failed to connect socket. 10060 (Unknown error)
12:57:47 T:8144 ERROR: CDVDPlayer::OpenInputStream - error opening [rtmpe://viacommtvstrmfs.fplive.net:1935/viacommtvstrm]
12:57:47 T:8144 NOTICE: CDVDPlayer::OnExit()
12:57:47 T:3668 ERROR: Playlist Player: skipping unplayable item: 0, path [rtmpe://viacommtvstrmfs.fplive.net:1935/viacommtvstrm]
12:57:48 T:3668 NOTICE: CDVDPlayer::CloseFile()
12:57:48 T:3668 NOTICE: DVDPlayer: waiting for threads to exit
12:57:48 T:3668 NOTICE: DVDPlayer: finished waiting
12:57:49 T:3668 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.southpark_unofficial/?mode=play&thumbnail=http%3a%2f%2f3.images.southparkstudios.com%2fimages%2fshows%2fsouth-park%2fepisode-thumbnails%2fseason-20%2fsouth-park-s20e08-members-only_16x9.jpg&title=Members%20Only&url=4483fdff-1094-448c-9c38-c5a06b287b0f
12:57:49 T:3668 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.southpark_unofficial/?mode=play&thumbnail=http%3a%2f%2f3.images.southparkstudios.com%2fimages%2fshows%2fsouth-park%2fepisode-thumbnails%2fseason-20%2fsouth-park-s20e08-members-only_16x9.jpg&title=Members%20Only&url=4483fdff-1094-448c-9c38-c5a06b287b0f) failed
12:57:55 T:3668 NOTICE: Storing total System Uptime
12:57:55 T:3668 NOTICE: Saving settings
12:57:55 T:3668 NOTICE: stop all
12:57:55 T:3668 NOTICE: stop player
12:57:55 T:3668 NOTICE: ES: Stopping event server
12:57:55 T:3668 NOTICE: stopping upnp
12:57:56 T:1652 NOTICE: ES: UDP Event server stopped
12:57:56 T:3668 NOTICE: stop sap announcement listener
12:57:56 T:3668 NOTICE: clean cached files!
12:57:56 T:3668 NOTICE: unload skin
12:57:56 T:3668 NOTICE: stopped
12:57:56 T:3668 NOTICE: destroy
12:57:56 T:3668 NOTICE: closing down remote control service
12:57:56 T:3668 NOTICE: unload sections
12:57:56 T:3668 NOTICE: special://profile/ is mapped to: special://masterprofile/
12:57:56 T:3668 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
12:57:56 T:3668 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
12:57:56 T:3668 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
12:57:56 T:3668 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
12:57:56 T:3668 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
12:57:56 T:3668 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
12:57:56 T:3668 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
12:57:56 T:3668 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
12:57:56 T:3668 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
12:57:56 T:3668 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
12:57:56 T:3668 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
12:57:56 T:3668 NOTICE: application stopped...
12:57:56 T:3668 ERROR: dllFreeLibrary - Invalid hModule specified
Damn, it's broken again... =_=
I'll try to fix it asap
Any news on the library option? Smile
I was afraid it might be related to my computer since I'm the only one with the problem and it has been down for more about a month now haha
Fixed and waiting to be updated on the official repository
Thank you a million can't wait to try it back !
Hey everyone, new to the forums here and appreciate all the effort put into the apps. I've been having a lot of trouble with my south park app lately and didn't know if it's just me. Looks like it's not from what I'm seeing.
I do not understand you comment. SP api keeps changing and i have to integrate 2 diffenrent (but similar) API (de + en)
Do you have a problem with it, even with version 0.4.5?
Hello!
Just want to ask if anybody here experiencing some kind of slowness in transition on the new Kodi Krypton? I noticed that on each episode there are a couple of clips it plays and from the previous Kodi version it transition smoothly without the loading icon showing. However, with the new Kodi Krypton it seems like it needs ~5- seconds to transition to the next clip.
Lastly, thank you Deroad for making this add-on I'm an avid southpark viewer and this really is a good add-on! Just out of curiosity, is it possible to have an optiopn where you can add the "opening theme song" of south park? I really like watching those because it shows how the animation progress throughout time.
Thanks again!
Hi, i didn't noticed that. i'll check.
For the intro, i'll look into that. i don't know where i they play it. on the official website they don't use it.
the ~5- seconds to transition problem can be:
11561 (PR)
2516745 (post)
adding "archive_cache" folder to .kodi/temp/ could solve your problem
I just updated to Krypton from Jarvis. I had previously used the beta of Krypton and really liked the UI, but the South Park addon wasn't working so I went back to the previous stable version of Kodi. Well, after having to do a refresh of my PC for something wholly unrelated, Krypton is the stable version and I'm finding the South Park addon still is not working. I can pull it up, see the list of seasons and episode thumbnails with descriptions, however when I click an episode it makes the sound like I've started it, has the rotating discs "hourglassing," says the episode is playing at the top of the screen, but then nothing happens. It doesn't go blank, I don't get the sound of an episode, it just stays on the episode selection screen. If I try to navigate away it'll brick Kodi. If I sweep to the left and get the options to come out, I can see the player controls and "stop" the playback and it acts like it really has stopped something and Kodi resumes working just fine. I'm not in front of my PC that has Kodi right now, but I think I do have the 0.4.5 version of the app, and would love to be able to keep watching South Park with my daughter without having to roll back to a previous version of Kodi since I do really enjoy the default ui of Krypton (it loads fanart so much more reliably than other versions). I've tried changing the location country with no joy there, I've even tried to change my location in my VPN with no luck, either.
Please feel free to break out the box of crayons, I can "get" most things with some instruction, if I'm missing something or need to tweak a setting in Kodi or even my computer, I'm willing to give it a shot.
Thanks for any help!
(2017-02-13, 16:55)Kitradu Wrote: [ -> ]I just updated to Krypton from Jarvis. I had previously used the beta of Krypton and really liked the UI, but the South Park addon wasn't working so I went back to the previous stable version of Kodi. Well, after having to do a refresh of my PC for something wholly unrelated, Krypton is the stable version and I'm finding the South Park addon still is not working. I can pull it up, see the list of seasons and episode thumbnails with descriptions, however when I click an episode it makes the sound like I've started it, has the rotating discs "hourglassing," says the episode is playing at the top of the screen, but then nothing happens. It doesn't go blank, I don't get the sound of an episode, it just stays on the episode selection screen. If I try to navigate away it'll brick Kodi. If I sweep to the left and get the options to come out, I can see the player controls and "stop" the playback and it acts like it really has stopped something and Kodi resumes working just fine. I'm not in front of my PC that has Kodi right now, but I think I do have the 0.4.5 version of the app, and would love to be able to keep watching South Park with my daughter without having to roll back to a previous version of Kodi since I do really enjoy the default ui of Krypton (it loads fanart so much more reliably than other versions). I've tried changing the location country with no joy there, I've even tried to change my location in my VPN with no luck, either.
Hi, i'm clueless. I have no idea why it doesn't work on your machine.
I'm using 2 versions of kodi too, to debug it, and i'm seeing some issues with the video (like frozen frames at the start when it buffers without the rotating discs) and some subtitles desync with the audio.
i think the best option is to stay away for a little from Krypton and use Jarvis which works great (from my point of view).
If somebody else will have other issues, i might think to remove this from Kripton and open an issue on github for that.
Sorry to report, I have the same issue as Kitradu. Hopefully, you don't have update it again for a while.Smile I would like to have it working, in Krypton too, because the PVR issues were fixed too. Love your app! Can't get enough of South Park!!! Big Grin Thank you so much for your diligent!! ~Tim
