2015-12-06, 10:59
2015-12-06, 10:59
2015-12-06, 12:25
i looked into the problem but unfortunately i have no clue which is the problem. links are fine but it doesn't play them. even rtmpdump 1.4 doesn't work...
2016-01-04, 09:27
(2015-11-10, 23:48)Deroad Wrote: [ -> ](2015-11-09, 22:38)polykoma Wrote: [ -> ]hi dudei'll fix asap but right now i'm quite busy :|
appreciating your great plugin
but im located in germany and cant watch the german stream (pi2 / V 16.0)
i changed settings to all kinds. didnt helped.
even location DE and EN stream work perfect.
but no german stream for me at all ...
any fix incoming ?
i planned also to add other langs since they are available like the de
In DE/Germany at the moment no chance to view episodes in german language.
Englisch no problem... ?
Did you have an idea what could caused the problem?
Is there any chance for an update?
Greetings by HushPeter
2016-03-02, 07:58
Delete.
2016-04-02, 01:01
Hey,
Is it possible to add Dutch language, the official site has it.
2016-04-02, 13:33
sure. Link to the dutch southpark website?
2016-04-21, 06:09
Minor bit of feedback here:
I'm in the US. Stock KODI Confluence skin. Running on my Intel Skylake NUC under OpenELEC/LibreELEC.
When I go to watch an episode, the "Working..." small popup stays on the screen for the whole episode. It's really obnoxious.
Tried on my older OpenELEC and the newer LibreELEC beta. Same result. On the latest Cutting edge Milhouse LibreElec build based on Kodi 17 the working indicator is center-screen so it's even worse.
Any ideas?
Any ideas?
2016-04-21, 11:23
hi Deroad,
can you update the german url and switch playback from rtmpe to hls?
line 119 to 122:
line 308-309:
line 119 to 122:
if audio == "de":
jsonrsp = getUrl("http://www.southpark.de/feeds/carousel/video/e3748950-6c2a-4201-8e45-89e255c06df1/30/1/json/!airdate/season-"+url)
#jsonrsp = JStoJSON(jsonrsp)
#jsonrsp = toUSJSON(jsonrsp)
line 308-309:
#if audio == "de":
mediagen += "&deviceOsVersion=4.4.4&acceptMethods=hls";
mediagen = mediagen.replace('{device}', 'Android')
2016-04-25, 10:37
Great Scott!!! Thanks for finding a fix for the DE lang, JinJin!!!! really appreciated! i'm releasing right now the fix.
@szalkerous I have no clue. maybe is a bug. try to use an original kodi build, instead of OpenELEC, LibreELEC.
2016-04-25, 11:07
no problem, thanks for updating.
the german url for the random part is also not working anymore. you can completely delete that part (lines 80 to 86) and use the international one instead. this is also working, playback will be german.
btw as stated above you can use hls for any audio language, not only de. <- this might fix playback issues on other platforms
2016-04-25, 14:42
oh, great!!
btw, i've fixed the random episode.
2016-04-26, 00:18
0.4.2 does not work work for me (Kodi 16, Win7), lang: ger, location: ger
00:08:33 T:13832 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'urllib2.HTTPError'>
Error Contents: HTTP Error 404: Not Found
File "C:\Users\xxx\AppData\Roaming\Kodi\addons\plugin.video.southpark_unofficial\default.py", line 429, in <module>
list(url)
File "C:\Users\xxx\AppData\Roaming\Kodi\addons\plugin.video.southpark_unofficial\default.py", line 120, in list
jsonrsp = getUrl("http://www.southpark.de/feeds/full-episode/carousel/"+url+"/c48e799a-9227-44d8-878f-248b0d065714").decode('utf-8')
File "C:\Users\xxx\AppData\Roaming\Kodi\addons\plugin.video.southpark_unofficial\default.py", line 243, in getUrl
response = urllib2.urlopen(req)
File "C:\Program Files (x86)\Kodi\system\python\Lib\urllib2.py", line 127, in urlopen
return _opener.open(url, data, timeout)
File "C:\Program Files (x86)\Kodi\system\python\Lib\urllib2.py", line 410, in open
response = meth(req, response)
File "C:\Program Files (x86)\Kodi\system\python\Lib\urllib2.py", line 523, in http_response
'http', request, response, code, msg, hdrs)
File "C:\Program Files (x86)\Kodi\system\python\Lib\urllib2.py", line 448, in error
return self._call_chain(*args)
File "C:\Program Files (x86)\Kodi\system\python\Lib\urllib2.py", line 382, in _call_chain
result = func(*args)
File "C:\Program Files (x86)\Kodi\system\python\Lib\urllib2.py", line 531, in http_error_default
raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
HTTPError: HTTP Error 404: Not Found
00:08:33 T:7836 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.southpark_unofficial/?mode=list&url=19
00:08:33 T:7836 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.southpark_unofficial/?mode=list&url=19) failed
00:08:33 T:12648 NOTICE: Thread LanguageInvoker start, auto delete: false
00:08:33 T:12648 NOTICE: -->Python Interpreter Initialized<--
00:08:33 T:4100 NOTICE: Thread BackgroundLoader start, auto delete: false
2016-04-26, 00:27
there is something wrong in that log.
this line:
doesn't exists.
download again the lastest version from the first post please.
this line:
doesn't exists.
2016-04-26, 02:19
Ok, I used the one from start post, but I reinstalled. But I cannot play a stream with Kodi 16 (alpha)
Any Idea?
But the good news is, that it works with mit Kodi 17 nightly
02:07:35 T:11604 ERROR: CDVDPlayer::OpenDemuxStream - Error creating demuxer
02:07:35 T:11604 NOTICE: CDVDPlayer::OnExit()
02:07:35 T:6424 ERROR: Playlist Player: skipping unplayable item: 2, path [https://cp112366-f.akamaihd.net/i/mtviestor/_!/intlod/southpark/video/Deutsche/Season_07/0714/acts/0714_3_DI_DEU_,480x360_400,640x480_600,640x480_800,.mp4.csmil/master.m3u8?hdnea=st%3D1461629243%7Eexp%3D1461643643%7Eacl%3D%2Fi%2Fmtviestor%2F_*%2Fintlod%2Fsouthpark%2Fvideo%2FDeutsche%2FSeason_07%2F0714%2Facts%2F0714_3_DI_DEU_%2C480x360_400%2C640x480_600%2C640x480_800%2C.mp4.csmil%2F*%7Ehmac%3D4cd9f6c20b03b31a84e197090c6ba5bfdb97f22abc5af4b917884bc4ba54ab2d&__a__=off&__b__=450&__viacc__=NONE]
02:07:35 T:6424 NOTICE: CDVDPlayer::CloseFile()
02:07:35 T:6424 NOTICE: DVDPlayer: waiting for threads to exit
02:07:35 T:6424 NOTICE: DVDPlayer: finished waiting
02:07:38 T:6424 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.southpark_unofficial/?mode=play&thumbnail=http%3a%2f%2f1.images.southparkstudios.com%2fimages%2fshows%2fsouth-park%2fepisode-thumbnails%2fseason-7%2fsouth-park-s07e14-raisins_16x9.jpg&title=Wir%20sind%20Grufties&url=60375d34-ecfd-11e0-aca6-0026b9414f30
02:07:38 T:6424 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.southpark_unofficial/?mode=play&thumbnail=http%3a%2f%2f1.images.southparkstudios.com%2fimages%2fshows%2fsouth-park%2fepisode-thumbnails%2fseason-7%2fsouth-park-s07e14-raisins_16x9.jpg&title=Wir%20sind%20Grufties&url=60375d34-ecfd-11e0-aca6-0026b9414f30) failed
02:07:38 T:10968 NOTICE: Thread LanguageInvoker start, auto delete: false
02:07:38 T:10968 NOTICE: -->Python Interpreter Initialized<--
02:07:39 T:13836 NOTICE: Thread BackgroundLoader start, auto delete: false
Any Idea?
02:02:40 T:11816 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.southpark_unofficial/?mode=play&thumbnail=http%3A%2F%2F1.images.southparkstudios.com%2Fimages%2Fshows%2Fsouth-park%2Fepisode-thumbnails%2Fseason-19%2Fsouth-park-s19e01-stunning-and-brave_16x9.jpg&title=Stunning%20and%20Brave&url=ed0508ac-1708-4865-835f-34d33e64a32f
02:02:40 T:11816 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.southpark_unofficial/?mode=play&thumbnail=http%3A%2F%2F1.images.southparkstudios.com%2Fimages%2Fshows%2Fsouth-park%2Fepisode-thumbnails%2Fseason-19%2Fsouth-park-s19e01-stunning-and-brave_16x9.jpg&title=Stunning%20and%20Brave&url=ed0508ac-1708-4865-835f-34d33e64a32f) failed
02:02:42 T:11816 NOTICE: VideoPlayer: Opening: https://cp112366-f.akamaihd.net/i/mtviestor/_!/intlod/southpark/video/Deutsche/Season_18/1807/,clips/sp_1807_clipHD_01_DE_B_384x216_300,acts/sp_1807_actHD_01_DE_B_512x288_450,acts/sp_1807_actHD_01_DE_B_960x540_1000,acts/sp_1807_actHD_01_DE_B_1280x720_1200,clips/sp_1807_clipHD_01_DE_B_1280x720_1200,.mp4.csmil/master.m3u8?hdnea=st%3D1461628972%7Eexp%3D1461643372%7Eacl%3D%2Fi%2Fmtviestor%2F_*%2Fintlod%2Fsouthpark%2Fvideo%2FDeutsche%2FSeason_18%2F1807%2F%2Cclips%2Fsp_1807_clipHD_01_DE_B_384x216_300%2Cacts%2Fsp_1807_actHD_01_DE_B_512x288_450%2Cacts%2Fsp_1807_actHD_01_DE_B_960x540_1000%2Cacts%2Fsp_1807_actHD_01_DE_B_1280x720_1200%2Cclips%2Fsp_1807_clipHD_01_DE_B_1280x720_1200%2C.mp4.csmil%2F*%7Ehmac%3Dd331341f317932b09b3096f0e8701d01db6a24772509efa6fe0ead85d760e894&__a__=off&__b__=450&__viacc__=NONE
02:02:42 T:11816 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
02:02:42 T:11752 NOTICE: Creating InputStream
02:02:43 T:11752 NOTICE: Creating Demuxer
02:02:43 T:11752 NOTICE: Opening stream: 0 source: 256
02:02:43 T:11752 NOTICE: Creating video codec with codec id: 28
02:02:43 T:11752 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
02:02:43 T:11752 NOTICE: Creating video thread
2016-04-26, 20:16
on the first log it seems it doesn't know what an mp4 is, so probably it's missing a codec/file format on that build
