Full Version: Mythtv add-on not working - nothing in logfile?
Hi all,
I'm trying to connect my Raspberry Pi 2 to my Mythtv backend using the Mythtv add-on.
The Pi2 has the OpenElec RaspberryPi Build (OpenELEC-RPi2.arm-5.0.8.img)
I've downloaded the latest add-on using wget http://janbar.github.io/pvr.mythtv/downl...-helix.zip
Installed the add-on from zip.
Configured and enabled the add-on (ip of backend is set correct, pin is set on backend, ipv6 on backend is ::1).
But nothing happens and I can't find any useful information in the log file, see http://xbmclogs.com/pkslep2ft
I've already tried different versions of the add-on, using OSMC instead of OpenElec but nothing seems to get it to work.
Strangely enough it did work earlier using OSMC but had issues where it didn't allow the Pi2 to boot (only showed grumpy face).
I can reach the backend using another pc with mythtvfrontend installed so the backend is operating and is reachable. Also the backend is reachable using the 6544 port and I can interface with the API.
Any help would be greatly appreciated because I'm now stuck.
From the log it looks like you haven't enabled the pvr.mythtv addon. There are two places you need to go in kodi:
1. settings|Addons|pvr addons|configure and enable pvr.mythtv
2. Settings|livetv|enable
Thanks nickr, that was it. That was a noob mistake on my behalf.
We were all new some time.
