2015-04-19, 00:30
Hi I'm hoping someone can help me please. I've jailbreak my ATV2 and I'm trying to install Kodi 14.2 or Kodi 15 and keep get errors.(I'm using the commands in my putty) here are error I'm getting with 14.2
Apple-TV:~ root# apt-get install wget
Reading package lists... Done
Building dependency tree... Done
You might want to run `apt-get -f install' to correct these:
The following packages have unmet dependencies:
org.xbmc.kodi-atv2: Depends: org.awkwardtv.whitelist
Depends: com.nito.updatebegone but it is not going to be installed
Depends: org.xbmc.kodi-seatbeltunlock but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Apple-TV:~ root#
And here are ones Kodi 15
Apple-TV:~ root# dpkg -i *kodi*.deb
Selecting previously deselected package org.xbmc.kodi-atv2.
(Reading database ... 1267 files and directories currently installed.)
Unpacking org.xbmc.kodi-atv2 (from kodi-20150120-e740097-master-atv2.deb) ...
dpkg: dependency problems prevent configuration of org.xbmc.kodi-atv2:
org.xbmc.kodi-atv2 depends on org.awkwardtv.whitelist; however:
Package org.awkwardtv.whitelist is not installed.
org.xbmc.kodi-atv2 depends on com.nito.updatebegone; however:
Package com.nito.updatebegone is not installed.
org.xbmc.kodi-atv2 depends on org.xbmc.kodi-seatbeltunlock; however:
Package org.xbmc.kodi-seatbeltunlock is not installed.
dpkg: error processing org.xbmc.kodi-atv2 (--install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
org.xbmc.kodi-atv2
Please and thank you.
Apple-TV:~ root#
org.xbmc.kodi-atv2
