2015-04-22, 12:48
Pages: 1 2
2015-04-22, 12:48
2015-04-24, 03:17
Really appreciate you working on this! It doesn't appear to be grabbing the thumbnails for the videos and when I play attempt to play them I get the following error: Playback failed. One or more items failed to play. Check the log file for details.
Here is the log file for the error:
Thanks for the help!![/php]
21:11:48 T:8132 NOTICE: Thread BackgroundLoader start, auto delete: false
21:11:50 T:7648 NOTICE: Thread LanguageInvoker start, auto delete: false
21:11:50 T:7648 NOTICE: -->Python Interpreter Initialized<--
21:11:50 T:7648 NOTICE: [plugin.video.break_com] Running: Break Videos (3.0.0) on Helix (14.2) with Python 2.7.8
21:11:54 T:6124 ERROR: CCurlFile::Stat - Failed: HTTP response code said error(22) for http://video1.break.com/dnet/media/723/849/2849723/kung-fu-monkey-attack-496_kbps.mp4?1B608EE7AFCE3765E176F3C6FBB98002B3D18C64572F2307D769AE7CA977F5BA90A3
21:11:54 T:6124 NOTICE: DVDPlayer: Opening: http://video1.break.com/dnet/media/723/849/2849723/kung-fu-monkey-attack-496_kbps.mp4?1B608EE7AFCE3765E176F3C6FBB98002B3D18C64572F2307D769AE7CA977F5BA90A3
21:11:54 T:6124 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
21:11:54 T:8168 NOTICE: Thread DVDPlayer start, auto delete: false
21:11:54 T:8168 NOTICE: Creating InputStream
21:11:59 T:8168 ERROR: CCurlFile::Stat - Failed: HTTP response code said error(22) for http://video1.break.com/dnet/media/723/849/2849723/kung-fu-monkey-attack-496_kbps.mp4?1B608EE7AFCE3765E176F3C6FBB98002B3D18C64572F2307D769AE7CA977F5BA90A3
21:12:02 T:8168 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 403
21:12:02 T:8168 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
21:12:02 T:8168 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
21:12:02 T:8168 ERROR: XFILE::CFileCache::Open - failed to open source <http://video1.break.com/dnet/media/723/849/2849723/kung-fu-monkey-attack-496_kbps.mp4?1B608EE7AFCE3765E176F3C6FBB98002B3D18C64572F2307D769AE7CA977F5BA90A3>
21:12:02 T:8168 ERROR: CDVDPlayer::OpenInputStream - error opening [http://video1.break.com/dnet/media/723/849/2849723/kung-fu-monkey-attack-496_kbps.mp4?1B608EE7AFCE3765E176F3C6FBB98002B3D18C64572F2307D769AE7CA977F5BA90A3]
21:12:02 T:8168 NOTICE: CDVDPlayer::OnExit()
21:12:02 T:6124 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.break_com/play/2849723/]
21:12:02 T:8096 NOTICE: Thread BackgroundLoader start, auto delete: false
21:12:02 T:6124 NOTICE: CDVDPlayer::CloseFile()
21:12:02 T:6124 NOTICE: DVDPlayer: waiting for threads to exit
21:12:02 T:6124 NOTICE: DVDPlayer: finished waiting
2015-04-24, 09:01
2015-04-24, 18:15
you are a vulcan!
just a hint, search would be nice!
Peppe
Peppe
2015-04-24, 21:42
(2015-04-24, 18:15)peppe_sr Wrote: [ -> ]you are a vulcan!
Peppe
Done
Version 3.1.0 (2015-04-24)
ADD: search
2015-04-25, 03:21
Well the problem turned out to be on my end. my router was acting a little strange. All is good now, thanks again for reviving this awesome plugin!
2015-04-25, 10:43
(2015-04-25, 03:21)vansmak Wrote: [ -> ]Well the problem turned out to be on my end. my router was acting a little strange. All is good now, thanks again for reviving this awesome plugin!Nice to hear...thanks and you're welcome
2015-04-27, 16:12
Hey bromix - Looks like I was using an old version of your break.com plugin and when I added your repo it upgraded itself to the latest version. Works great obviously but the old version had a "Newest or Just Added" option to browse.
Any chance of bringing that back?
Thanks mate.
-Chris
Thanks mate.
-Chris
2015-04-27, 19:08
(2015-04-27, 16:12)chrisric Wrote: [ -> ]Hey bromix - Looks like I was using an old version of your break.com plugin and when I added your repo it upgraded itself to the latest version. Works great obviously but the old version had a "Newest or Just Added" option to browse.Use 'Featured' it's the same result.
Thanks mate.
-Chris
2015-04-28, 03:22
(2015-04-27, 19:08)bromix Wrote: [ -> ]Use 'Featured' it's the same result.
I thought the older version displayed an unfiltered list, something like: http://www.break.com/videos/newest/just-submitted/
Maybe I was wrong
2015-08-01, 22:42
Version 4.0.0 (2015-08-01)
UPD: framework
UPD: framework
2015-08-07, 18:51
Version 4.0.2 (2015-08-07)
FIX: localization was missing a text and the ID was wrong
Version 4.0.1 (2015-08-07)
UPD: moved from *.xml to *.po localizations
UPD: framework
UPD: framework
2015-11-27, 19:26
4.0.3
- forum url (thx 2 NEOhidra)
2018-03-27, 04:54
Featured Break Videos have not been updating for the past week or so. Will there be an update?
2018-04-11, 00:45
Featured Videos are still not updating. Is this official addon dead?
Pages: 1 2
