Hi
I'm running EMM 1.4.06 x86 and want to upgrade to new version.
Is it possible to keep my settings so I don't have to do it all again?
Yes, just install the new version over the old. Database will be upgraded automatically, old settings will also used.
Please check the hints (also hints from older releases) in download thread.
How do we export and import our settings?
All settings are in the settings folder.
(2015-05-09, 11:39)DanCooper Wrote: [ -> ]All settings are in the settings folder.
Cool.
Though I think you should have an import/export settings as a file menu item.
This will allow easier to backup and restore.
So it backup all settings and program data to a zip/rar/7z file.
Just something to consider for a future release.
