2015-05-10, 07:54
2015-05-10, 09:58
Which categories do you have disabled in the skin settings?
2015-05-10, 12:40
I disabled everything excpet Movies, TV Shows and System
2015-05-10, 14:03
Yeah, that will make it start up with the tv shows category.
Actually, the only way to make it start up with the Movies category, is to disable tv shows and settings and add them as custom categories.
You can add the same widgets and submenus - the only thing you will lose, is the add-on shortcuts for the tv shows category (if you use them).
