Full Version: auto rename movie folders only
How can I
-auto rename movie folders, not files , after it has finished scraping..
I have enable the settings under bulk renamer options
and I clear the file pattern settings.
I have also enabled the three checkbox
-automatically rename files during...
But so far it is not working.
I would like to keep the original filename intact because it contains useful information.
You have to fill both fields, folder and file name.
Use $F to keep the old file name.
(2015-05-10, 18:21)DanCooper Wrote: [ -> ]You have to fill both fields, folder and file name.
Thanks..
Though from a user's Point of view, it would be more easier to understand/use if you had a checkbox.
-Rename folders only, not files.
If you put a checkbox on that option.
The filename textbox would be readonly, so you can't input any $ code.
Or it would put the $F code in the textbox, and make it read only.
I don't think everyone understands or reads all those $ codes.
