2015-05-13, 10:25
Kodi, running on raspberry pi (model B+) hangs after being on and idle for a while. I run it on a raspbeery pi behind the tv, which is intended to be just running as a server. It simply does not respond to CEC anymore
I noticed that this problem does not appear in 14.0, but does appear in 14.2 The raspberry pi is fine. Obviously I don't want to reboot my Pi every X days, it should just keep on working. When answering, keep in mind that the hardware (pi) is nearly unreachable and should be treated as a separate serverroom and the Pi is only being operated by CEC via the HDMI. (and no, it's not the tv)
As a workaround I can reboot the PI now, but that is not a sustainable solution in the long run. Can you please test keeping the pi idle for a long time (at least 3 days) and try to get it running with CEC again?
