2015-05-15, 07:21
I was under the impression recordings would show up foldered, but both addons only show me a flat, disorganized view of recordings. Can anyone give me some ideas, or confirm that it should work at least?
(2015-05-15, 07:21)bluenote Wrote: [ -> ]I was under the impression recordings would show up foldered, but both addons only show me a flat, disorganized view of recordings. Can anyone give me some ideas, or confirm that it should work at least?
(2015-05-15, 19:06)robo989 Wrote: [ -> ](2015-05-15, 07:21)bluenote Wrote: [ -> ]I was under the impression recordings would show up foldered, but both addons only show me a flat, disorganized view of recordings. Can anyone give me some ideas, or confirm that it should work at least?
You set this up on the backend GUI.
Login the webgui, then go "Configuration" tab, then "Recording" sub tag.
On the right there is options for filename and directory name/creation for recordings.
Your selection should be what is shown in Kodi/XBMC.
Make sure to restart tvheadend service/reboot to ensure you're running with the new options.
Recordings should then appear in the format you like, tree/date etc.
