2015-05-15, 23:27
Hello,
I have a problem when I try to download the subtitles using video add-ons from all of the sources, like PipocasTV or LegendasDivx.
The error:
22:19:43 T:6952 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.UnicodeDecodeError'>
Error Contents: 'ascii' codec can't decode byte 0xc3 in position 11: ordinal not in range(128)
File "C:\Users\Fl�via\AppData\Roaming\Kodi\addons\service.subtitles.pipocas\service.py", line 537, in <module>
subs = Download(params["id"], params["filename"])
File "C:\Users\Fl�via\AppData\Roaming\Kodi\addons\service.subtitles.pipocas\service.py", line 416, in Download
log(u"Saving subtitles to '%s'" % (local_tmp_file,))
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 11: ordinal not in range(128)
22:19:43 T:7096 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://service.subtitles.pipocas/?action=download&id=33797&filename=Breaking.Bad.S05E01.HDTV.x264-FQM/AFG/ORENJI/CrrlHD hits: 331 uploader: PT-Subs
Version: Kodi 14.2
How I can solve this error?
The error:
Version: Kodi 14.2
