2015-05-21, 13:12
Hi there,
i need a solution for following problem:
I installed Kodi on Mavericks and want to use the entertain Iptv (rtp stream).
But the stream stops after about 2 min. If i switch to another channel, the picture is scrambled, green, grey, etc.
If i use VLC with the playlist it runs fine with no problems.
I checked it also on Snow Leopard with the same settings in Kodi and it runs with no Problems.
So it must have to do something in Mavericks, also tested it on Mountain Lion with the same bad result.
I checked it also on different Macs, the same problem appears. On Snow Leopard all is good, on ML or Mavericks the stream breaks.
All the different Cache Settings didnĀ“t help.
Do i need a special patch for a library or what?
It feels really strange for me.
Hope somebody can help me.
regards
regards
