Full Version: Zespl Filmowy Oko.png ?
When I do a backup of my Kodi setup it hangs on this strange file. 'Zespl Filmowy Oko.png'
The only search on google for this brings up a thread on the Transparency Forum.
My setup uses this skin. Im hoping if I can locate and delete it, my backup might work. But I cant find it anywhere.
Can anyone help me? Strange request I know!
that file should only exist if you've ever used the git/svn version of the skin.
check if they are located here:
../skin.transparency/media/flags/movies/studio/Zespól Filmowy Oko.png
../skin.transparency/media/flags/movies/studio/Zespół Filmowy Oko.png
Thanks for the reply. That media folder has no subfolders in it. Just one file, Textures.xbt. Could I be missing something?
nope. if you installed the skin through the repo, all images will be packed in 1 file, Textures.xbt.
