Since "Classic TV" is no longer available what is everyone using to create the shortcut for Kodi to the home screen on the Amazon Fire TV stick?
I can not figure out the coding to add the kodi image to I Kono. When I was using Classic it was easy. I know I need to change the name of the image to match I Kono but to what? Im am baffled and have gone thru so many different steps and what I thought was what I should do that im almost to the point of giving up. So I have turned to you once again. What is the process for changing the icon from I Kono to kodi.
u can use fire starter its an apt need to side loaded but thats the easiest way
