2015-05-23, 11:23
Hi all,
I have a nearly perfect setup going apart from my audio/video which randomly glitches. If you rewind then the glitch will not be in the same place. I can confirm that the file plays perfectly on several other devices. The main culprit is the audio which I've attached debug logs of it occurring several times during The Beatles - "Happiness Is A Warm Gun.flac". The Debug Log: http://xbmclogs.com/pwmdqkr4q seems to show that the flac only plays for 5 seconds, unless I am reading it incorrectly, however the entire song did play and paused several times towards the end. It's driving me nuts.
My System Setup
Thank-you,
Luddite
My System Setup
- Kodi 14.2
- Kodibuntu 14.04.2 LTS 64-bit (Clean install + apt-get update, upgrade, dist-upgrade) onto a 60GB internal SSD
- Intel Celeron 2820 NUC with 8GB ram connected to the router via 1Gb ethernet
- QNAP TS-420 NAS (192.168.0.6) with all media on it connected to the router via 1Gb ethernet
- Harmony 515 remote
- Sony Bravia monitor connected to the NUC via HDMI
- NAD D3020 USB direct amp (working perfectly with kodibuntu connected to the NUC via USB2 (both analog and digital S/PDIF show the stutter) - never had a issue with it before on windows or ubuntu)
- Debug Log: http://xbmclogs.com/pwmdqkr4q (Go to the section where The Beatles - Happiness is a warm gun.flac is playing as that song had multiple stops in it)
Thank-you,
Luddite
