Hello , i have Kodi 14.2 on my Amazon fire Stick , when i exit kodi sometimes it freezes on Exit , anyway i can fi it , i have my debug.log file if thats any good
http://xbmclogs.com/pahxwxvya
anyone know what i need to fix ?
I had this issue too, mine was resolved by changing the fullscreen option to use a window rather than true fullscreen.
still hanging on Exit on my fire stick
(2015-05-24, 22:52)Karnage11 Wrote: [ -> ]Hello , i have Kodi 14.2 on my Amazon fire Stick , when i exit kodi sometimes it freezes on Exit , anyway i can fi it , i have my debug.log file if thats any good
Can you make a new log where it captures the actual shutdown? Do to this you'll need to go into the add-on log uploader's settings and enable "upload old log", and then give us that link. If you're not sure which link is the old one, then just give us both links.
The most likely cause for a freeze or long exit is an add-on waiting to be shut down. The log should show us which add-on is causing the issue, or at least where to start looking.
Those are both the same log, and not the old log.
it is enabled , now where do i go to get it ?
hoping i did it right lol
can anyone tell me what is wrong please
Debugging wasn't turned on for the log, but it still shows a complete shutdown. It could be an add-on causing the lockup, but it's hard to say without debugging turned on.
See
log file/Easy (wiki)
once it is enabled , use Kodi log uploader ?
