Full Version: Mac Mini 2009 upgraded to yosemite + kodi - Having issues?
Hi I upgraded the OSX to YOSEMITE and installed KODI yesterday (May 25, 2015).
FYI, I have been using Harmony remote with Plex profile with no issues previously!.
After I installed KODI I changed the remote to UNIVERSAL and my audio pointing to my RECEIVER! Everything worked fine until I rebooted the mac!
Interestingly when I reboot the harmony remote does not work or the mac does not respond!
The fix was to switch on my RECEIVER again (looks like the HDMI behavior of mac has changed using YOSEMITE - The only variable in my setup is MAC) and everything works ok!
I do not know what to make out of this?
Another anomaly I have noticed......
When using tvheadend PVR client & AEON NOX the EPG is blank! however if i change the skin to default CONFLUENCE the EPG shows up! Has anybody else faced similar problems?
This is caused by OS X 10.10 however there is an easy fix. Download and install the candelair remote driver. The driver is free and it should resolve your issues..
