Full Version: Openelec VDR freezes regularly
I am currently runnong OE5.0.8 on a NUC celeron 2820
I use VDR to get live DVB-T TV
VDR version 1.3.0(Protocol: 8)
Every so often, Live TV freezes, causing the entire system to eventually crash and needing a reboot
After freeze I can restart watching Live TV, but it will freeze again after only a few seconds
-- Logs begin at Thu 2015-05-28 07:44:44 CEST. --
May 28 19:35:17 NUC vdr[1998]: [1998] DVBAPI: 0.0: status 'ready'
May 28 19:35:17 NUC vdr[1998]: [2047] DVBAPI: 1.0: status 'ready'
May 28 19:35:17 NUC vdr[1998]: [2047] DVBAPI: CaInfo: 1.0 sending CA info
May 28 19:35:17 NUC vdr[1998]: [2046] DVBAPI: CaInfo: 0.0 sending CA info
May 28 19:35:18 NUC vdr[1998]: [1998] ERROR: no OSD provider available -
using dummy OSD!
May 28 20:44:04 NUC vdr[1998]: [2062] VNSI-Error: cxSocket::read: read()
error at 0/4
May 28 21:32:40 NUC vdr[1998]: [2310] ERROR: cLiveStreamer stream
processor thread 2313 won't end (waited 5 seconds) - canceling it...
The following message repeats every time I retry to watch live TV:
May 28 21:44:32 NUC vdr[1998]: [2500] ERROR: cLiveStreamer stream
processor thread 2503 won't end (waited 5 seconds) - canceling it...
can you provide more information about the versions used by OE? I have not released 1.3.0 yet, so I need to know git revisions. Also please provide full debug log of kodi and syslog with vdr logging level set to 3
The backend seems to be @ 2.2.0:
NUC:~/.kodi/addons/service.multimedia.vdr-addon # cat changelog.txt
4.3.11
- update to vdr-plugin-restfulapi-0.2.1.4
4.3.10
- disable dvbapi network mode
4.3.9
- update to vdr-2.2.0
- update to vdr-iptv-2.2.0
- update to vdr-satip-2.2.0
- update to vdr-plugin-dvbapi-c0c7fa2
- update to vdr-plugin-eepg-9cd9a75
- update to vdr-plugin-vnsiserver-9529e6d
- update to vdr-plugin-streamdev-84c6f6b
considering the frontend, I can't figure out how to determine the version that is used, also can you explain me how to set VDR logging level to 3 ?
I was referring to vnsiserver which turned out to be an unreleased development version in OE 5.0.8. Should be updated in OE 6.0
