2015-05-30, 21:52
I'm experimenting with changes necessary to support ATSC <m>.<n> channel numbering. Started by comparing with Confluence skin. I currently seem to have them working. Here are the changes I have made:
Change all occurrences of "ChannelNumber" to "ChannelNumberLabe"l. This affects files DialogFullScreenInfo.xml, DialogPVRChannelManager.xml, DialogPVRChannelsOSD.xml, DialogPVRGroupManager.xml, DialogSeekBar.xml, MyPVRChannels.xml, VideoFullScreen.xml, and View_PVR.xml.
The resulting wider channel number overlaps the VideoPlayer.ChannelName and Player.Title elements of the OSD. Changed the <posx> element from 400 to 430 on these two labels in file VideoFullScreen.xml. Reduced <width> element from 720 to 690 for VideoPlayer.ChannelName and added <width> element of 690 to Player.Title.
The OSD changes work fine for 99.9 channel numbering, and should probably work better for 9999 numbering as well. However, I can't test that and I'm not sure about the correctness of the width settings in relation to the progress bar. It doesn't seem like those values were explicitly measured anyway.
I hope these changes are suitable for adding to the official addon. I like the skin quite well and hope to continue using it permanently. Thanks for all the hard work.
