2015-06-16, 22:20
Dear all,
I recently wanted to change my setup to have a central DVB-S/ S2 appliance in my network. The card I chose was a Digital Devices Cine S2 (v6.5), my system is a Debian Wheezy based one with OpenMediaVault on top of it.
So I installed the drivers according to it's necessities and was able to install TVHeadend 3.9.2827~g477feab~wheezy on my box.
The first configuration worked - after some problems - quite well and about 800 channels were able to be mapped.
So far, so good. But finally, I wanted to have the Live-TV via Kodi on Amazon Fire TVs and a Windows machine, so I installed the TVHeadend HTSP Client (v 1.9.40) and configured it according to my needs (IP Adress, and user/ pass as set in the Access entries tab on TVH).
On one of my machines (the Windows one), the EPG was read, but when I try to access the Live TV, I receive an error in Kodi, stating "HTSP Client: stream setup error" and "Disconnected from Server".
The logfile on the server side says:
The client on the Windows machines states:
From my point it has to be an issue between TVHeadend and Kodi, as when I try to access the live TV via VLC, it works.
What I did so far after reading several sites on the net was to:
- Set the "Full DiseqC" to enabled,
- set the standard streaming of the user to matroska and
- a complete reinstallation.
Unfortunately, none of these methods did the trick. Therefore I hope to any suggestion on how to solve my problems.
Thank you for your feedback,
best regards,
Connor
Jun 16 22:15:33 OMV tvheadend[1624]: htsp: Got connection from 192.168.1.20
Jun 16 22:15:33 OMV tvheadend[1624]: htsp: 192.168.1.20: Welcomed client software: XBMC Media Center (HTSPv8)
Jun 16 22:15:33 OMV tvheadend[1624]: htsp: 192.168.1.20 [ XBMC Media Center ]: Identified as user tvh
Jun 16 22:15:33 OMV tvheadend[1624]: htsp: 192.168.1.20 [ tvh | XBMC Media Center ]: Privileges raised
Jun 16 22:15:33 OMV tvheadend[1624]: htsp: unable to create profile chain 'matroska'
Jun 16 22:15:35 OMV tvheadend[1624]: htsp: 192.168.1.20 [ tvh | XBMC Media Center ]: Disconnected
22:13:54 T:7736 ERROR: AddOnLog: Tvheadend HTSP Client: CHTSPConnection::ReadResult - 'subscribe to channel' failed - Stream setup error
22:13:54 T:7736 ERROR: AddOnLog: Tvheadend HTSP Client: CHTSPDemux::SendSubscribe - failed to subscribe to channel 1681037008, consider the connection dropped
22:13:54 T:7736 ERROR: AddOnLog: Tvheadend HTSP Client: CHTSPDemux::OnConnectionRestored - failed to subscribe to channel 1681037008
22:13:54 T:7736 NOTICE: AddOnLog: Tvheadend HTSP Client: CHTSPConnection - CHTSPConnection::SendGreeting - connection opened to 'HTS Tvheadend 3.9.2827~g477feab~wheezy', protocol v20
best regards,
Connor
